02-02-2011, 03:51 AM | #1 |
need advise on brakes....
Has anyone tried this brake kit? Or any of their products?
Posted via Mobile Device |
02-02-2011, 12:13 PM | #2 |
Re: need advise on brakes....
I too am in the market - so I wll be watching this one.
I called them to see what spindle they run with their kits - ECE or Western was the answer.
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
02-02-2011, 12:40 PM | #3 |
I think project "incredible hulk" is using these brakes. They look to be a quality product. Its in the builds section somewhere
02-02-2011, 03:10 PM | #4 |
why not check out ECE? I have had very good customer service from them, used their Front susp rebuild kit and love it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-02-2011, 04:13 PM | #5 |
I don't think they offer anything bigger then a 12", and no rear set up? Plus it never hurts to shop around.
02-02-2011, 08:40 PM | #6 |
OutOfMyMind & I'llNeverKnowWhy
Anyone know how much those rotors weigh?
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
02-02-2011, 09:29 PM | #7 |
ok i spoke with them and they have the 71-72 spindle, i have 73+ balljoints. can i make it work? i would have to remove my lower arms to have them pressed again.
02-02-2011, 09:43 PM | #8 | |
67-72 parts collector,…
You will need to change your upper ball joint to the 71-72 version. The lower ball joint is the same. The outer tie rod will have to be changed to the 71-72 version. Pretty simple if you want these brakes.
02-02-2011, 09:45 PM | #9 |
Yep, you'd need to use 71-72 ball joints. Tops obviously are a bolt-in swap, the BJ would have to be pressed out & swapped for the lowers if it's not already the same size (might be).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-02-2011 at 09:45 PM. |
02-02-2011, 10:38 PM | #10 |
Watch out for your cornhole !
Keith is right, the lower ball joint is the same 71 through 87. Upper is 71-72 and 73-87 fitment.
02-02-2011, 11:32 PM | #11 |
Thats good news, I can do the uppers as they are bolt on. The tie rod shouldnt be a problem as im running a dropmember. Thanks for the knowledge guys.
02-02-2011, 11:45 PM | #12 |
What spindles do you have on there now?
02-03-2011, 01:01 AM | #13 |
they make the parts for the mcgaughys kits ...
it usual better and faster if u figure it out yourself!!!! |
02-03-2011, 01:08 AM | #14 |
Stock 73 spindle. I have a 2inch Z so I didnt want to buy spindles till I mocked it up. I hope to lay 24"
