Old 02-02-2011, 02:33 PM   #1
RIDDLA
RIDDLA's Avatar
Question BBC Motor Mounts Not the perches HELP
Its a 68 gmc ive cut the frame so the BBC perchs fit got them working. But the motor mounts are givin me hell!
I was using small block mounts.
Can i use them? What do i need?What have you all done.
68 GMC-Stripshow
70 Chevy Monte Carlo
72 Chevy Monte Carlo LOLO
72 Chevy Suburban Blurban
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
03 Cadillac Escalade-Duecesix
84 Cadillac Coupe Deville DeElegance
B.O. A Lifestyle Money Cant Buy!
Win,Lose, or Tie
I'm a Raider till i die
RIDDLA is offline   Reply With Quote
Old 02-02-2011, 02:39 PM   #2
hot trux
'85 Stepside
hot trux's Avatar
Re: BBC Motor Mounts Not the perches HELP
you have to use bb engine mounts as well. alot diff. google within this site(toward top of page) and there will be pics
hot trux is offline   Reply With Quote
Old 02-02-2011, 03:12 PM   #3
Dynomutt
Dynomutt's Avatar
There are different types of stock BB perches, pre 72 and 72 only. Depends on which you installed but I ran pre 72 perches and SB motor mounts on my 72 for years and it worked fine. These are the ones with a single bolt that goes through the perch from the bottom and screws into the SB mount (Very similar to SB mounts, first pic).
Here are some pics for you to see the differences if you aren't already aware. The first pic is pre 72 BB perches which look just like the SB perches but have "cups" above the motor mount hole so the exhaust will fit. I'm not sure about a 67 but they fit in the same frame holes as the SB mounts on my 72. The second pic is the 72 perches and mounts. They are a clamshell type motor mount and are completely different from the others. I'm not aware of a SB mount that works with these perches but there may be some.
I have no idea what mods need to be made on a 67 to get the perches in. Are you sure the perches are in right? That will make a huge difference in whether or not the mounts line up right.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 02-02-2011, 03:35 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Not true. I've always run small block mounts on the big block stands. If you search, I did an FAQ article on it with pictures.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-02-2011, 05:42 PM   #5
RIDDLA
RIDDLA's Avatar
Yes i bought the perches from a trusted member here 68-71 mounts.
I had to cut some of the frame its was as wide as my other 67 Mines a 68 GMC
68 GMC-Stripshow
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
Win,Lose, or Tie
Old 02-02-2011, 06:50 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
I don't think you would have to cut anything. And the small block mounts should work. Do you have some pics of what is going on?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-03-2011, 02:31 AM   #7
RIDDLA
RIDDLA's Avatar
Well in 67 the frames are wider than 68-72 where the perches mount to. from what i read My 68 was wide were the perches sit.
So cut of some metal and got the perches workin good bolted to the front v8 holes. Some 68-72 didnt have the wide frames due to big blocks coming out that year from what i have read.
68 GMC-Stripshow
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
Win,Lose, or Tie
