02-05-2011, 03:31 PM | #1 |
Junior Member
No Limit 63-72 Rear Shock Kit
NO LIMIT ENGINEERING New Rear Shock Kit to fit 1963-72 Chevy Pickups!! "Quote per Rob" - I'm feelin pretty good about this. After dropping another 2" in back, we ran into the same trouble as everyone else. The shock issues. After researching the other kits, and solutions, and thinking about it, we came up with a plan. Here are some of the problems we noted. 1. No room for a longer shock, even with reworked or 'dropped' mounts. 2. shock angle gets worse, the lower you go. 3. If we go another 2" (8 total) we're screwed again. 4. the exhaust is a nightmare. 5. the inboard shock design doesn't handle that great. With this in mind, we set out for a fix. This is the whole idea behind the JT, to come up with tested components that WORK, and will HELP get more trucks on the road to be enjoyed.
Michelle No Limit Engineering Authorized Dealer for: Ridetech, Vintage Air, Painless, Ididit, Accuair, Flaming River, and many more |
02-05-2011, 03:32 PM | #2 |
Junior Member
Re: No Limit 63-72 Rear Shock Kit
We are also using this forum, and site to set the record straight. I am sure we will be copied. Now there is lasting, dated proof, and those who 'knock-off' will be called out. This kit will come with 2 different length shocks. A 10" stroke shock for the stock to 4" drop guys, and a 8" stroke shock for the 6" to 10" drops. Once the stock shocks and mounts are gone, the new lower mounts are a direct replacement.
02-22-2011, 11:14 PM | #3 | |
Man of Mini-Talents
I gather from the smoldering mount, this is not an unbolt the old and bolt on the new operation. Is the price $185? Combo price with the trac bar kit?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro Last edited by Zoomin; 02-22-2011 at 11:20 PM. |
02-25-2011, 05:41 PM | #4 |
I think Michelle at No limit posted and ran...
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
03-03-2011, 09:05 AM | #5 |
This is a duplicate post which violates Site Rule XIV:
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you. A question about the strength of the lower mount for the No Lomit kit was previously posted and that post was transparently moved by an administrator to the "duplicate" post ??? Here is a link to the other post: http://67-72chevytrucks.com/vboard/s...Rear+Shock+Kit Last edited by lakeroadster; 03-04-2011 at 03:22 PM. |
02-05-2011, 03:33 PM | #6 |
Junior Member
The new upper mounts locate to the frame with a factory 5/8" hole. We provede a big bolt to hold and align the new mount. You have to drill the two 3/8" holes.
02-05-2011, 03:34 PM | #7 |
Junior Member
Then your all but done. Just bolt on the shocks and mount studs, all included.
02-05-2011, 03:35 PM | #8 |
Junior Member
Quote from Rob, "After some drive time, I am happy to report that the difference is clear. Body roll is reduced, and the ride is very smooth. The outboard location is a benefit in many ways. With a good quality monotube shock, these kits wil run about $185.00 I think thats a good deal for the gains. Just remember, You saw it here FIRST."
02-05-2011, 09:09 PM | #9 |
67-72 parts collector,…
Thanks for releasing your "New Products" here at 67-72ChevyTrucks.com.
We will be looking forward to future 67-72 suspension products from No Limit Engineering!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-05-2011 at 09:36 PM. |
02-05-2011, 09:28 PM | #10 |
Looks good. Now I just need another truck.....
Doug Looking for a 67-72 short bed driver..... |
02-06-2011, 07:14 PM | #11 |
will there be a coilover option
72 SUPER10 |
02-22-2011, 02:03 PM | #12 |
"This kit will come with 2 different length shocks. A 10" stroke shock for the stock to 4" drop guys, and a 8" stroke shock for the 6" to 10" drops. Once the stock shocks and mounts are gone, the new lower mounts are a direct replacement"
What about those of us that dropped 5"? Will you offer just the brackets/hardware?
03-04-2011, 03:45 PM | #13 |
pm sent but waiting for response.
Maybe I should call?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
08-03-2011, 05:00 PM | #14 |
Junior Member
Sorry guys, I have been out of the loop - for a LONG WHILE -
I'm back!! These kits are all done, ready to go!! A) 0-4" Drop Spring (B) 5-7" Drop Spring Part # 3GC-RR-100 Complete Mounting System----------$149.00 (without shocks) Part # 3GC-RR-101 Specify A or B So Cal Shocks-----------$73.00/pair (soft and smooth) Part # 3GC-RR-102 Specify A or B Doetch Hydrolic-------------$119.00/pair (mild/med, good with air bags) Part # 3GC-RR-103 Specify A or B Doetch Nitro--------$139.00/pair (Med/Firm, canyon carver) Part # 3GC-RR-104 Specify A or B Bilstien Invertia Valve---------$258.00/Pair Smooth, self adjusts to conditions) Part # 3GC-RR-105 Specify A or B Romic Billit with adjustable rebound-----$269.00/pair Great for performance tunning Please give us a call @ No Limit 909-386-7637 or pm me with a private message if you are interested.
10-05-2011, 11:59 AM | #15 |
Michelle,
Just wondering if the rear shock kit will work on the 73-87 trucks that have been converted to trailing arm rear suspension? Love the kit and would like to use it on my truck. Thanks in advance. Russell |
12-08-2011, 09:58 PM | #16 |
Active Member
Hi Michelle
I have called u twice now and was told by a real nice lady who pick up the phone that u would call me back.I want to buy a set of the rear shock mounts but I want kyb gr2 shocks because I have a new set on the front can u give me a part # to one of the shocks so I can cross ref to the kyb I have a 1969 c10 s/b with a 4 inch drop coil Thanks Doug |
12-09-2011, 12:39 PM | #17 |
For that drop you would use an 'A' shoch length. 12" closed, 21" open, 17" RH. Both eyes are 5/8". Doetsch #3163 (hydrolic) #9163 (nitro), or Bilstien # 55-R042. Sorry for the delay, hope that helps.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
