02-06-2011, 08:38 PM | #1 |
what you guys doing for more leg room
I have not got to drive my 70 step yet do to broken right foot. But I went and sat in it the other day for the first time and not alot of room. But I am 6.3 and 370. Truck does not have tilt and differnt bucks that sit a little high and doesnt have tilt wheel. Seem like its not going to be the must comfortable thing to drive. but I do have this huge boot cast on my foot. any suggestions other then tilt and putting tank under bed. I dont know anything about these trucks first one.
02-06-2011, 09:22 PM | #2 |
Re: what you guys doing for more leg room
Do a search on shorting a colomn. The colomn can be actally "pushed" down towards the steering box to gain room. I am sized very similar to you and when my 68 had the regular stuff in it it was tight to sat the least and not fun or comfortable to drive. My truck also has the buddy buckets and I think they may set a little higher as well. A smaller diameter sterring wheel might help, unless you truck is not equipped with power steering[ smaller wheel=harder to turn] I put in the tilt in my truck and the "trick of pushing it towards the dash was used as well. The shift collar on my colomn is almost toching the dash gromet. But when you push down the colomn it seems to lessen the tilt effects, may have something to do with the shorter leveror something like that. Hope this helps .Now if I have really confused you I will try better next time let me know if I need to clear anything up for you. by the way welcome. Jim
02-06-2011, 09:43 PM | #3 |
454 MAKES IT ROAR
Here's Putters how to thread on shortening the column, one of the first mods I did and it worked a treat....won't help on leg room mind.
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
02-06-2011, 10:11 PM | #4 |
The easiest thing to do would be to buy a newer truck. They make them bigger every body style change. The seat in a 67-72 will only go back so far, and moving the tank will do nothing for that. You can move the column like others said, but the leg room will always be the same unless you were to extend the cab.
02-07-2011, 12:14 AM | #5 |
Well that will help out alot it looks like I will have a little more room for my big ole belly. Yes it would just be easeir to by a newer truck but already have 2 newer trucks with lots of room. But I love the 67-72 trucks and now that I have one I need to make it more comfy to drive even thow I havent drove it yet just sat in it like a kid reving the motor up. Thanks alot guys this site is so helpful all ready. SO putting the tank under the bed doesnt give it any more seat room I just thought it would. It seems like the brake pedal needs to go back a little. But it might just be this big ole boot cast thing on my foot.
02-07-2011, 03:03 PM | #6 | |
Location: Formerly MD and San Diego, now loving life in Arizona
Thanks for the link to the steering column! I am going to work mine this weekend. AL '69 GMC 2500 Custom Camper '69 Chevy C10 396 |
02-07-2011, 01:48 AM | #7 |
Truck and auto performance nut
it seems like to me with the available space behind the front wheels...that the floor could be cut at the front where it begins to tilt upward, flat sectioned stretched a forward a couple of inches, then modify the section between it and the bottom of the firewall to seal everything back up. If this is possible in reality and not just in my mind....seems like it would be a popular kit, if someone made it.
No?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
02-07-2011, 03:19 PM | #8 | |
http://www.powerblocktv.com/magazine/ JULY 2010 ISSUE PAGE 12 GIVES YOU A ROUGH IDEA OF HOW TO DO THIS AS THEY DID IT WITH ROOM TO CLEAR 22" WHEELS |
02-07-2011, 07:34 PM | #9 |
The steering column mod is one partial solution to the problem. I also fitted a smaller steering wheel to mine, a 12 1/2" Grant wheel ... of course I have power steering ... this let my thunder thighs slide under easier. And if I had thought of it in time, I would have had my upholsterer reduce the thickness of the foam in the seat by an inch or two. That might not work for those who want stock upholstery, but my seat upholstery isn't stock. Each of these mods allow you to pick up an inch or two in critical areas. It ain't ideal, but it does help.
Barry L. Van Hook '69 Chevy Frankentruck |
02-07-2011, 10:03 PM | #10 |
has anyone ever droped the seat w/o the gas tank behind the seat
02-07-2011, 05:17 AM | #11 | |
Posted via Mobile Device |
02-07-2011, 12:17 PM | #12 |
My 70 has power brakes and the rod was adjusted so that the brake pedal is as close to the floor as possible ( but still works well ) now, I just move my foot over to the brake from the gas pedal, without having to "lift up" my leg - it DOES help !!!
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
02-07-2011, 02:48 PM | #13 |
the boat guy
just push that skinny pedal through the firewall works for me.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
