Old 02-08-2011, 12:40 AM   #1
DG Racing
DG Racing's Avatar
1957 frame dimension ?
ok i have a 1957 3600 frame and i need to know what is the dimension of the same frame but a 3100 model
the dimension i m looking is the distance betwen the frame at the front axle my 3600 is 29 1/2 inch
DG Racing is offline   Reply With Quote
Old 02-08-2011, 08:28 PM   #2
kaycee
kaycee's Avatar
Re: 1957 frame dimension ?
My 58 1/2 ton says 34" that would be outside to outside of frame, 30" inside to inside
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 02-08-2011, 11:39 PM   #3
DG Racing
DG Racing's Avatar
Ok my frame is 34 inch wide but the frame rails are 2 1/4 wide at the front axle ,so it makes a distance of 29 1/2 .
so that means that a 3100 frame is only 2 inch wide ??
this info is for a installation of a mustang II crossmember
Because the crossmember i receive is only 29 inch wide
Old 02-09-2011, 12:22 AM   #4
kaycee
kaycee's Avatar
Now according to my 58 manual it shows the 3600 as 34 " wide allso<I would get ahold of company that you are going to use and ask them.I would think that it would at least be 29 3/8th wide ,but I'm wrong most of the time.
2005 FXDWG stage3
63 IMPALA 327
Old 02-09-2011, 12:31 AM   #5
DG Racing
DG Racing's Avatar
its because nobody make them for 3600 frame , and i never trust manual
Its alway better to have the real measurements , so this forum is the best place to have the exact info .
From a good measuring tape
Old 02-09-2011, 01:45 AM   #6
OrrieG
OrrieG's Avatar
This should help, shows specs for the different frame sizes.
http://chevy.oldcarmanualproject.com...esto/56134.htm
Old 02-09-2011, 10:27 PM   #7
DG Racing
DG Racing's Avatar
I just received another confirmation and yes
a 3100 its 29 1/2 between front rails
So i have to call the seller now
Thanks everybody for your help
