Stock air conditioning with LS swap
Is anyone here using the factory ac their truck came with? I am to the point where I need to start making plans for the ac and where to put this trinary switch that the pcm uses to control the fans and ac compressor..
Any help or pictures would be much appreciated.
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD. 1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc |
Home Built '87
Re: Stock air conditioning with LS swap
Read Glock's build.
Specifically around post #656 & 1309
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
Already read through his build, the ac on his 85 is a bit different than the 68, which I forgot to mention.
Are you dead set on keeping the Expansion valve/ POA valve/ Receiver Dryer system? It would be cheaper & easier to replace the Evaporator core with a fixed orifice style evaporator (Ive found 77 Olds 98 evaporators fit the best) & run a Accumulator & Orifice tube.
What year/make/model did your LS come out of? GM put the high side trinary in different places, sometimes in the discharge side, sometimes in the liquid line. |
#5 | |
The engine is from a 2007 Trailblazer SS LS2. The ac compressor is a Denso 10S17F from a 2005 Silverado 5.3. Thanks, Greg
![]() Join Date: Nov 2007
Short-T,
I am in the process of installing a vintageair evaporator in my 65 but I am trying to use the ECM to control the fans and the AC clutch like you are. I have a 2005 LS2 from an SSR (E40 ECM). What it uses is a pressure transducer that the ECM uses to protect the compressor in case of over or under pressure. Then it uses the pressure values to determine when no fan, 1 fan, or 2 fans need to run. There are tables in the ECM that you can modify if you want. So I bought the pressure transducer from GM and an adapter from Doc's Blocks and I am going to aluminum braze it in the compressor discharge line. I am using the stock LS2 Sanden scroll compressor that came with the engine. That is the last part of my AC install so not quite finished. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Thanks TR! I look all over Docs Blocks and didn't see that...
I went through your build and love the work you have done. Must be a pleasure to drive and show off at the show's. How do you like the way the LS2 performs? Greg
#8 | |
Yea, I looked thru Doc's several times, and ordered the wrong one once before I found it. Then it is $1.57. I paid more than that for WhopperJr for lunch today. Thanks for the kind words. The LS2 is better than I imagined it would be. Starts every time, idles perfect in all conditions, completely docile until you open it up, then hold on. It has been dead reliable since I started it last July. Loves to cruise at 75. Daily driver. TR
BMW & ASE Master Certified
I wired the a/c up without that switch... only things i have in the circuit is the low psi switch and the compressor clutch, and a/c relay... operates like it should from facotry with the ecm controlling the a/c relay.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Short-T,
I brazed that adapter into my high pressure line today and fabricated the compressor block. Looks like it will work OK. TR
I'm finishing up an 82 with an 03 dbw truck 5.3 /4l60e and looking for help with the 03 high pressure switch to turn fans on with ac. Fans already working wired parallel but how do I get them coming on with the a/c. Any advice or links would be greatly appreciated. Thanks in advance to anyone who might be of assistance
[QUOTE=MB Customz;7333025]I'm finishing up an 82 with an 03 dbw truck 5.3 /4l60e and looking for help with the 03 high pressure switch to turn fans on with ac. Fans already working wired parallel but how do I get them coming on with the a/c. Any advice or links would be greatly appreciated. Thanks in advance to anyone who might be of assistance.
#13 | |
I know this is an old thread but I don't want to make another thread since this is already on the topic. IBread through this and noticed everyone here was talking about using as much of the factory 67-72 AC boxes with the factory EFI LS motor and original compressors to the LS series motor. But for me I'm not running the stock/factory Intake and fuel injection or computer, I have a 67 with factory AC and At first I will run my engine carburated, (yes I know it's quite possibly the stupidest thing to do to an engine which is already fuel injected) I'm looking to find out how to hook up the factory AC of the 67, to the my 2002 5.3 from a silverado. I'm open to switching evaporators/condensor/reciver dryer to other units as long as they fit in the evaporator box and on the radiator support with little modifications, I would like to run 134a instead of r-12 and I know as of 1990 you need a low and high pressure switch so the system does not vent refrigeration out. Im also willing to getting a different AC compressor and bracket if there is one that can be used better or easier with the 67 then the one I currently have. I'm having some problems fitting the AC compressor bracket to the block with my motor mount plates as they stick out further forward, I was thinking about clearencing the bracket but I don't want to structurally compromise the bracket, what are your guys thoughts? I suppose there is the high mount AC option as well, but I do like how the compressor is tucked in out of the way with the low mount.
#15 |
![]() Join Date: Aug 2010
That's how I did mine as well. I used the stock 5.3L compressor with the Old Air system and it looks and works great. Old Air is nice because you can buy a kit that doesn't include the compressor, condenser, or hoses and save some $$$.
67 5.3L Build |
#16 | |
You can also just buy the evaporator unit from Vintageair. That is what I did. By the way. It is not a switch. It reads the high side pressure. Then in the tune you have tables that allow you to turn one fan on and off at one set of pressures and a second fan on and off at another set of pressures. Keeps the fan use to a minimum. Of course the system would run fine without that. TR
#17 | |
I have a question....How are you guys sending a A/C request to the PCM without the factory control head? Or does the factory "pressure transducer" signal turn the fans on/off based on pressure, speed etc., without a A/C request? |
#18 |
To send an A/C request to the PCM, you just take the wire that originally went to the compressor clutch, and wire it to the A/C request wire going to the PCM. The catch is, you can only do it on the 2002 and older systems, as the 2003 and up the request is sent via serial data. There has been some talk about being able to change certain files in the tune with Tunercat to be able to use the newer PCM with the older style 12v A/C request, but I haven't looked into it much.
#19 |
Old member
I used all the factory AC boxes but upgraded everything to 134A products. The air system system looks pretty much stock.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#20 | |
John from Speartech told me that the newer motors (mine is 2008) with the serial AC request will automatically adjust the RPM for the added load. He appears to be right since that is exactly what mine does when I turn on the compressor.
67 5.3L Build |
#21 |
TR, looking good! Are you using the ac compressor that came with your engine? If so I'd like to know how you mounted it to the engine after replacing your oil pan?
Keep up the great work! Greg
#22 | |
Yep, I am using the OE compressor. The mounting was a real ordeal, so bad I don't even have any good pictures. So as you know, the truck oil pan doesn't have the two lower compressor mounting holes. I spaced out the compressor with 5/16" spacers on the top block mounting holes. That gave me room to bolt a 5/16" aluminum plate to existing block mounting holes and provide holes for the lower compressor mounting bolts, I put nuts on them. It also took some clearance machining on the compressor mounting cradle and the compressor itself. Moreover, I need that 5/16" for frame clearance. I also had to cut a access hole in the crossmember to reach the lower rear compressor mounting bolt. So far I have not had to cut the frame for clearance, that is my goal. I am determined to use the low mount compressor. So, I hope all the above works. The pic below shows some of it. TR
#23 | |
Nice job on the switch fitting, I ordered mine last week so its hurry up and wait! Greg
#24 |
interesting.. I used the factory 5.3 a/c compressor and mount, and didnt have to space anything out. My compressor has a different manifold, a 2 seperate hose set. none the less the a/c works awesome... easily hits 50* out the vents
![]() clint
#25 | |
Posted via Mobile Device |
