Old 02-09-2011, 04:03 PM   #1
blazer2007
rear bag bracket placement ?
Just wonderin how to determine where to put brackets on the rear so I have the proper air in the bags for ride height.It will be brackets welded on axle and a top crossmember setup.Is on a 78 blazer
blazer2007 is offline   Reply With Quote
Old 02-09-2011, 06:58 PM   #2
SCOTI
SCOTI's Avatar
Re: rear bag bracket placement ?
Set the vehicle @ ride height.
Make a 'dummy' air bag to use as a set-up tool. A piece of pipe or block of wood the correct dimension for the bag @ manufacturers recommended specs (air psi & height) will work for this.
One you have those two things done, you can get an idea of the placement required for the upper/lower brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-09-2011, 07:13 PM   #3
blazer2007
thanks ,I didn,t know they gave you psi ,height etc with the bags.
Old 02-09-2011, 08:06 PM   #4
SCOTI
SCOTI's Avatar
While not an exact, their recommendations should get you started & in the ballpark.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
