Old 03-15-2003, 12:46 AM   #1
AJII
AJII's Avatar
Quick Question
Ok guys here it goes...
On my truck, the crank pulley is out of line. The alternator and water pump are perfect, but the crank pulley extends out about 1/4" too far.
Is it possible that the pulley is on backwards and makes it stick out too far?
Or might I have the wrong pulley? Or the wrong harmonic balancer?
Thanks!
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 03-15-2003, 12:47 AM   #2
AJII
AJII's Avatar
BTW: the engine was rebuilt, and put back together like this and driven like this before it was wrecked. But I want it fixed, while its easy to get to.
Old 03-15-2003, 04:36 AM   #3
twistedmetal
Take it to the limit
twistedmetal's Avatar
the harmonic balancer may not have bottomed out against the lower timing gear and may need more zapping with the impact gun,or i ve seen it happen a few times where people have tapped on the lower gear inbetween crank and the back of the gear because the gear was kinda siezed on from years of service and actually marred the surface of the crankshaft thus not allowing the lower timing gear to bottom out against the crankshaft an leaving the balancer sticking out further than its supposed to.If the crank is marred where the timing gear slides on,you should be able to use emerycloth or a file to remove the burred surface on the crankshaft.HOPE THIS HELPS
"If Fall Guy only knew how many trucks i wrecked,He'd be proud"
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
