Old 02-12-2011, 06:33 PM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
GMC headlights
Ok, dumb question but how are the headlights configured on a GMC? Are all the bulbs the same and the inner pair just aimed higher for the high beams? I thought there was only one style of T3? Are only 2 on at a time when on high or low?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-12-2011, 06:40 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: GMC headlights
outers are low/high inners are high only.
when on in low beam, only the outers are on
when on in hight beam, all 4 are on.
T3 made both the inner and outer, plus the larger 7 inch bulbs too
Old 02-12-2011, 06:46 PM   #3
Vintage Windmills
Vintage 4x4s
Re: GMC headlights
Thanks Andy, so all four bulbs are the same?
Old 02-12-2011, 06:59 PM   #4
Re: GMC headlights
No. He said the outers are hi/lo beam and the inners are hi-only...inner= single element and outer = double element. T-3 was a series of bulb made by Wagner,I believe. I'd have to check. Haven't thought about it for a while. T-3s are like Super Blues or other series made by the same company.
Old 02-12-2011, 07:07 PM   #5
Vintage Windmills
Vintage 4x4s
Re: GMC headlights
Just looked at my 2 GMC's and it looks like the inners are marked with a "1" and the outers are marked with a "2". I also just learned the headlight bezel is a little different between a 69 and a 67 in that the 69 has reliefs for the screwdriver so the bezel can stay while the headlights are worked on
Old 02-12-2011, 07:25 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
Re: GMC headlights
I think you will find a double plug on one headlight, and a triple on the other. And you are correct, 67 didn't have any notches to aim the headlights in the bezel. Most 68s did, but not all.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-12-2011, 09:52 PM   #7
Vintage Windmills
Vintage 4x4s
Re: GMC headlights
Yep, I noticed that after I got them out. Good news, I've got 3 T3's for the 67.
Old 02-12-2011, 10:08 PM   #8
463
463's Avatar
Re: GMC headlights
http://www.sylvania.com/ConsumerProd...RG-Results.htm here is part #s that are the new replacement #
High beam headlamp
H5001
Low beam headlamp
H5006
Trueman
463 is offline   Reply With Quote
Old 02-12-2011, 09:00 PM   #9
sjarrett71
sjarrett71's Avatar
Re: GMC headlights
The headlights are 2 different part numbers at the parts store too.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 02-13-2011, 01:46 AM   #10
Longhorn Man
Re: GMC headlights
they make repro T3 lamps now... so don't spend too much time looking for 40 year old lamps.
