02-15-2011, 08:23 PM | #1 |
fan belt squeal?
All is fine until I get to about 2800 RPM on the highway, then I get a loud squeal that I assume is from a fan belt. I have tightened both belts (one for alternator and one for power steering) but it didn't solve the problem. (I know the expensive solution is to get an overdrive transmission so I don't need to run at 3000 RPM, but with 4.11 gears and a non-overdrive TH350 I have to work with what I have).
Next step is to remove one belt at a time to try to find out which one is making the noise. Both the water pump and alternator are new, so it should not be shaft/bearing problems. Any other ideas? |
02-15-2011, 08:33 PM | #2 |
I built it
Re: fan belt squeal?
tried belt dressing yet? thats worked for me before
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
02-15-2011, 09:28 PM | #3 |
20' Daredevil (Ret)
Unfortunately, belt dressing has not worked for me. If you can safely hold a bar of soap against each belt (one at a time so you can find the culprit), it will temporarily stop the squealing. Obviously keep your fingers, knuckles, clothing etc. out of belts & pulleys....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-15-2011, 08:50 PM | #4 |
Rev it up like that while you watch the belts and pulleys under the hood. I wonder since they are slipping at a steady high rpm,and not when you "snap" it,if there isn't an alignment problem causing the belt to not ride deep enough in the pulley. I have had a chronic belt slip when I revved the motor and using a deep groove Z/28 pulley on the alternator solved it. It was misaligned just a bit and I never could get it quite right. Never did figure it out.
02-16-2011, 12:21 AM | #5 |
The belts are the kind with the notches on the back side, maybe I'll try another brand if I can't solve it some other way. A little narrower wouldn't hurt, it would fit down in the groove a little better.
02-16-2011, 12:28 AM | #6 | |
Moderator
I agree, the deeper the belt sits in the pulley, the more "grab" it has, and the less likely to slip. In fact, I would be willing to bet that WILL solve your problem. It did in my case. Belt dressing has NEVER worked for me, only made the problem worse. Carefully holding a bar of soap along the edge of the running belt as Stocker described above has worked many times for me...however it is only a temporary fix as stated.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 02-16-2011 at 12:31 AM. |
02-16-2011, 02:26 AM | #7 |
Make sure the belt isn't bottoming out on a severely worn pulley. This is evidenced by a shine on the bottom side of the belt......
02-16-2011, 03:12 AM | #8 |
Heres my delema, i have brand new pullies on the crank and water pump, a new alternator with new pully, i have test ran the engine without the pullys and get no squeal at all, i only get squeal with the alternator belt as i have tested with just one belt then the other. I have tryed both running a little too tight and a little loose.. I can see no visable sign's of missalignment.. I have tryed both Gates and Dayco belts to no avail.. My only other possible thought is that the 4X4 3/4T trucks supposably use a smaller diameter water pump pully from what i have read than the 1/2T to increase waterflow, so maybe the smaller pully creates more drag and is the source of the squeal? I plan to try a fan clutch some day to see if that helps.. yea its a pita for sure..
EDIT: Try using the search feature and type in belt squeal and you should find more threads on the subject.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 02-16-2011 at 03:14 AM. |
02-16-2011, 09:30 AM | #9 |
It's usually at the alternator that they slip since that's the smallest pulley. You guys should try the Z/28 pulley. It helped me. They are designed for just this problem with hi-performance motors. They are deeper and solid. I don't a picture or I'd show you.
02-16-2011, 10:43 AM | #10 |
It's all in the timing
dsy1,you said you replaced the water pump and alt.When you installed the belts were your hands free of grease(clean).Kind of an obvious question but just a thought.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
02-16-2011, 01:54 PM | #11 |
Where would i find such a pulley?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-16-2011, 02:29 PM | #12 |
i had a simular stubborn squeek with my power steering. No dressing would solve the problem. Ended up beign slight mis-alignment. Pulled the pump, added a spacer so it lined up perfectly. Problem has completely gone away.
02-16-2011, 02:56 PM | #13 |
if a belt squeals normally it's a good sign that it needs to be replaced ...
