Old 02-15-2011, 11:47 PM   #1
firedog
firedog's Avatar
my wintertime time killer
so my engine crapped out again, i cant complain much it last a couple of years and i bought it straight from the junk yard and put it straight into my truck. so this time thanks to dad (sammy) we found a 350 on craigslist. The guy that had it acquired when buying out a garage and didnt know anything about the engine. it looked like a fresh rebuild with assembly lube visible visible in all the right places. it was minus the intake, oil pump, valve covers and oil pan. So a deal was struck and we took it home, it even came with the engine stand. so now to the fun part removing the old and in with the new. even with heat in the garage there hasnt been many decent days to mess with it but here is pics to show what we have done up to now.
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-15-2011, 11:54 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: my wintertime time killer
Cool deal...saved you lots of time too! Subcribed.
ETsC10 is offline   Reply With Quote
Old 02-15-2011, 11:54 PM   #3
firedog
firedog's Avatar
the numbers show a 4 bolt main truck engine, the heads are from a 400, we have been slowly adding parts to it from the old to the new, you can see half of the serpentine set up here
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 02-16-2011, 12:01 AM   #4
firedog
firedog's Avatar
and a few pics of my truck taking up space in dad's garage
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 02-16-2011, 12:14 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Looks sweet... I'd remove that fram paper weight off of there though.
Old 02-16-2011, 08:59 PM   #6
Sammy
Nice weather 75 today. Added the other Serp bracket, WP, cleaned the Intake up with some cleaning n paint, used a can of carb cleaner on the carb. Alls left before install is torque the intake, add the PS Pump, finish installing the Dampner (need to rent the tool), plugs n wires and dist., and adj the valves. Clean n prep the truck frame of gunk.
See if I have an update pic.
Fram is for intial run.
#8 Rod on the ol motor is toast with about 1/16th inch of play.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-16-2011, 10:02 PM   #7
Sammy
Details on replacement engine: New ..cam, lifters, push rods, crank, rods, pistons, dbl roller timing gear, and freeze plugs. New bearings cam, crank etc. Block was machine shop cleaned. Heads have new valves with springs and have been been reworked. Everything clean as a hounds tooth on a hot August day.
Updated pics added.
Old 02-16-2011, 10:27 PM   #8
firedog
firedog's Avatar
Wow thanks dad I spent the majority of the day sleeping... Two more night shifts then back to days and the way normal people live
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 02-16-2011, 10:31 PM   #9
firedog
firedog's Avatar
I noticed you are saving the power steering pump for me...
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 02-16-2011, 10:32 PM   #10
Sammy
No...actually needed to sample a cold beverage..haha
Old 02-19-2011, 11:04 PM   #11
firedog
firedog's Avatar
well no progress this weekend so far... however headed to a swapmeet tomorrow to look for goodies... hopefully the "early spring" continues so we can get back at it this week
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 02-19-2011, 11:10 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I hear the early spring, weather rocks here this past week or so!
Motor looks really good!
John
1999 Toyota Tacoma 4x4
Old 04-20-2011, 08:28 PM   #13
abebummy26
abebummy26's Avatar
Looks good man. Parents just ordered a camper from down by you guys. Did you get it all put together? Oh and did you get an exhaust with a little higher ground clearance put in?
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 04-20-2011, 09:14 PM   #14
mightymouse
mightymouse's Avatar
hey; firedog nice project. i just got some brackets and pulleys out of wrecking-yard like yours . and went to my local Chevy dealership and ask if there was an a/c compressor delete and he said no that the only difference was belt length . and i was checking out your thread. and seen yours.and sammy's too. is my parts-man wrong? or did y'all make your own? i also picked up another bracket without air-pump provision. please help...thanks
mightymouse is offline   Reply With Quote
Old 04-21-2011, 08:42 AM   #15
Sammy
It has been awhile ago that we got those delete AC pulleys. The last one I ordered on line. By using google search option. Typed in a search "A/C Delete Pulley" and it sent me to where to order mine. Firedogs we got thru a savy local parts place. He ordered it came in the very next day. Coulda been as much as $22 shipped if I recall correctly?? On mine..after installing the pulley there was a smaller Serp runner pulley just below where you put the delete pulley that had to also be removed as it kept throwing the belt off. Removed it without any additional complications. If you can't find the delete pulley make another post I do a search find the part number for you.
Old 04-21-2011, 08:50 AM   #16
Sammy
http://platinumparts.com/da-1698-2100002.aspx here is one but I didn't see a price. You can always get a part number off one of the sites and shop around or even order thru your local guy too. Good Luck.
Old 04-21-2011, 10:45 AM   #17
brad_man_72
the boat guy
brad_man_72's Avatar
no more slow truck!? victory shall be mine!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-21-2011, 12:09 PM   #18
Sammy
Actually have run into a stumble..not sure yet about the valve adjustment and timing. Very hard to determine TDC with a serp system masking the timing mark. Battery giving us fits and my charger went dead. But shes pumping oil. Will revisit this W/E with the setback.
Old 04-21-2011, 07:27 PM   #19
mightymouse
hey/ Sammy. thanks for reply on a/c delete. i ordered one thru different dealer-ship.probably paid too much. didn't mean to get in yawl's way. but you've been helpful.thank-you . hope you get timing like you want....j.w
Old 04-21-2011, 07:53 PM   #20
Sammy
NP..yeah I'm going to look at battery chargers that are on sale tomorrow. Maybe you can send some dry Tx weather up this way so I can get something done on Firedogs Trk.
Old 04-22-2011, 11:00 AM   #21
RCbowtie69
RCbowtie69's Avatar
Looking good,truck looks good too.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 05-19-2011, 09:23 PM   #22
firedog
firedog's Avatar
Well got the Timming and valves adjusted and it started!! Oh ya look out now sounds mean! Got a nice little lope from the cam I'm excited!!!
What's that under the truck? Oil leak!! Thought it wasthe oil pan crawled under took it down put it back together... I fire it up... Still leaking .... Grrr looks like I am gona have to do the rear main now! Add to that I threw my back out an not gonna be able to crawl under it for a few more days
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 05-19-2011, 11:34 PM   #23
70cst
70cst's Avatar
Good thread-Good reading
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-20-2011, 12:13 AM   #24
LockDoc
The Older Generation
LockDoc's Avatar
You guys better hurry... only four months left...
LockDoc
Leon
Old 05-20-2011, 03:18 AM   #25
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm glad to hear you got it running. Sucks to hear about the oil leak. Good luck with it!
Ryan
1969 Chevy milk truck
