Old 02-17-2011, 01:41 PM   #1
FL71C10
Engine wiring help
I need help temporarily wiring my motor to start it. The wiring in the truck is a mess and I am trying to get the engine hooked up so I can see if it runs ok. I know the heavy positive battery cable goes to the starter (already hooked up). The s terminal on the starter is the one I hook to my switch to engage the starter? Also, a positive wire goes from the battery directly to the distributor? That one I just disconnect to shut it down? it's a 75 or 75Impala 350 with an hei distributor. Is that all I need to know? Obviously I'll wire it up to the ignition key when I permanently hook everything up, but I just want to test start it to see if it will run.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-17-2011, 01:58 PM   #2
MARKDTN
Re: Engine wiring help
The small starter terminal closest to the block says "S". That is the start terminal. Go from there to the battery through a momentary switch to start. If you have an HEI, all you need is a good 12v source from battery to the distributor cap. If you don't care about the alternator, that's all you have to have to make it run.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-17-2011, 02:40 PM   #3
fixit-p
fixit-p's Avatar
Don't forget the negative cable to the engine block
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 02-17-2011, 03:29 PM   #4
FL71C10
There's a battery ground cable run ning from the battery to the alternator bracket. Do I need one to the engine block as well?
Old 02-17-2011, 03:49 PM   #5
70chevykidd
70chevykidd's Avatar
no you don't need one to the block the alternator bracket is a good ground also
70chevykidd is offline   Reply With Quote
