Old 02-18-2011, 06:50 PM   #1
2003 silverado
2003 silverado's Avatar
Smile Snow ball effect
It all started out as bad frt brake line and bad Rad. next thing i know iam replacing fuel pump/water pump/brake line/rad support/inner fenders/ETC/ETC. I Love it
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 02-18-2011, 07:45 PM   #2
AJs72K5
AJs72K5's Avatar
Re: Snow ball effect
That right there is classic "Might as well" syndrome. No known cure.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 02-18-2011, 10:01 PM   #3
SBTork
Garage wrench
SBTork's Avatar
that is 100% true!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-19-2011, 04:03 PM   #4
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
In '95 my dad bought a 51 chev fleetline deluxe. After driving it for a few weeks i came in the garage and was horrified when i saw the whole front clip removed. $60,000 and a 6 year frame off later he got it goin again. He just put a 700r4 in it last year. Its a full blown addiction. It never ends.
mustardjimmy71 is offline   Reply With Quote
Old 02-18-2011, 09:13 PM   #5
2003 silverado
Iam thinking about pulling the motor and having it rebuilt LOL
Old 02-19-2011, 06:47 PM   #6
SleepyK5
I have developed a bad case of snow balls! I am now down to the frame and practically evrything will be new!
SleepyK5 is offline   Reply With Quote
Old 02-19-2011, 07:03 PM   #7
2003 silverado
Taik about Balls deep (LOL). I did that 15yrs ago and still have it apart This one is my second and Iam trying to keep it a driver
Old 02-20-2011, 07:59 PM   #8
2003 silverado
Ok today i managed to get back out and did some more work $140 later. replaced t-stat and painted the housing/water pump chevy orange. I managed to get the water pump/ t-stat/fuel pump /new belts/LMC rad support(bad move)Gaps to big. Hope to get the innert fenders in soo<and get it running soon
Old 02-21-2011, 12:01 AM   #9
Critter
Future TOTM Winner
Critter's Avatar
It happens! I started off pulling mine apart to rebuild/restore back to basically stock. Phase two of the snowball effect came when I decided to go with an LSx 6.0...then OD tranny, then 8 lug axles, etc, etc, etc. I hope to have it back together in 20 years or so.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 03-01-2011, 09:18 PM   #10
2003 silverado
Ok got things some what together see pics . I was able to drive it around the block for the first time since I owned it,I need new brakes,some bad gas in tank,trying to burn off,The steering is little loose,I went to start it today and heard some bad noise under hood and it wont start(Iam Thinking the Dist spun on me )What do you guys Think?? Was able to crank and wanted to start but wont
SEE Lessons learned
Old 03-01-2011, 09:57 PM   #11
my90k5
72 K/5 Junkie
my90k5's Avatar
Ah hell lightning bolt, sounds like you need to find that #1 plug, lol. I just put a piece of tissue paper shoved inside #1 turned it by hand and it just made the purty’est pop when that #1 came around. Was the distributor loose?
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 03-02-2011, 07:24 AM   #12
2003 silverado
No the dist is tight/when I started to cranking it yesterday I heard some noise weird noise like something every 180 degree, She was running really good for sitting for some time 4-8yrs .It started all day sunday everytime,Ist there a wheel/sprocket on the bottom of dist,hell on with a sheer pin????(Its been a while since I worked on these oldies,you should have seen me with the fuel pump,DAM PIN)
Old 03-02-2011, 01:59 PM   #13
2003 silverado
Now I think I have a bigger problem.It started fine today but running rough and theres a noise in the engine not a valve tap something lower(maybe spun baring????
Old 03-02-2011, 04:13 PM   #14
my90k5
72 K/5 Junkie
my90k5's Avatar
I was going to say if it was running good then it's proly not the dist. That's not a sound you want to hear
My Build Progress
Old 03-02-2011, 04:21 PM   #15
2003 silverado
if its a rod nock would that make it run rough???
