Old 02-18-2011, 08:04 PM   #1
trapperjack
trapperjack's Avatar
63 K10 project---picture heavy
I'll post pics first, and ask questions later. Texas rig, minimal rust, mainly door corners. Was a ranch/hunting truck. I'm told they blew the third member in the front pumpkin towing it from Houston to Waco using the towbar. Disonnected the driveshafts, but left the hubs locked in. Pretty solid body though. Brushed on house paint camo.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 02-18-2011, 08:11 PM   #2
trapperjack
Re: 63 K10 project---picture heavy
I'm told it's a 235, how to tell for sure? I'm guessing it's a 420 4 spd? Reverse is left and down. Divorced t-case, what should it be?
Big question, what other year front axles will go in without much fuss?
Thanks for any quick easy answers. I'm searching the faq's for other things like year model changes (doors/dash/etc).
Old 02-18-2011, 08:36 PM   #3
skoffice
skoffice's Avatar
Cool truck! Not a bad looking huntin rig. I'd swap a D44 open knuckle/disc brake axle under the front from any '71 and up chevy/gmc. Don't forget to put a new proportioning valve in to acommodate the disc brakes. I'm pretty sure you are correct about it being 235/sm420 and I think a rockwell t-case. Looks to me like someone put in a rear end from a 2wd truck judging by the panhard bar stud in the 2nd to last pic. Check to make sure what gears are in it, and that they match whatever you get for a front end. Maybe the PO didn't check the gears when they put that rear end in and that contributed to the front end giving up? They must be the same or you will tear up the t-case, or the next weakest link.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-18-2011, 08:44 PM   #4
trapperjack
I saw that, wasn't sure if maybe it had had a sway bar at one time, or had been swapped in from a 2wd.
Old 02-18-2011, 09:05 PM   #5
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
I have owned several of these trucks that had a rear end swapped in from a 60's 2wd truck and had the mount for the stablizer bar as yours has. The transmission is a SM420 and the transfer case is a Rockwell T221. I dont know about the engine all mine have had 283 V-8's. Have you been over to the 4x4 forum and checked out the thread "Lets see how many 60-66 4x4's are out there". If not you need to check it out.
66Gilbert is offline   Reply With Quote
Old 02-18-2011, 09:32 PM   #6
trapperjack
I'll go check it out, thanks. Just trying to figger out what I got. Lots of reading here. Gotta love it.
Old 02-18-2011, 10:55 PM   #7
padresag
are you sure that it is a 63 as 63 did have the 230 and a 292 eng. it may be an early 63 as I think that some of them did get a 235
ron
padresag is offline   Reply With Quote
Old 02-19-2011, 12:31 AM   #8
Bugeyev8
Bugeyev8's Avatar
looks like a 62 to me by the location of the emblem and the grill, in any case it looks like a great truck !!
Bugeyev8 is offline   Reply With Quote
Old 02-20-2011, 05:07 PM   #9
sasquatch5308
sasquatch5308's Avatar
safety third!
1962 swb 4x4
1952 Chevy "turd bucket" truck
1953 Buick special
1953 Famous James motorcycle
1975 Scout II
sasquatch5308 is offline   Reply With Quote
Old 02-20-2011, 05:11 PM   #10
sasquatch5308
It's a 62 like mine. That's a one year only grille and headlight bezels. Also the location of the side badges and hydraulic clutch. Is the motor mount in the front with a plate that goes behind the timing cover?
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-20-2011, 05:14 PM   #11
sasquatch5308
Also you have clear turn signal lenses.63 had amber ones. So unless they swapped out the front end.... its a nice lookin truck though, mines in pieces.
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-20-2011, 09:21 PM   #12
trapperjack
Yep, mounts up front under the harmonic balancer.
So just what is the oil capacity on this 235? Wanted to do an oil change, first couldn't find the filter (figgered that one out), but can't find a capacities chart anywhere. Going for oil/plugs/beer tomorrow.
Also, what to look for on wipers? Needs a fuel pump, they're asking if it's vac or elect....the fuel pump in it now doesn't have any vac outlets, but there are vac looking hoses going under the cowl.
Thanks, all.
Old 03-20-2011, 02:49 PM   #13
A.T. RockDriller
A.T. RockDriller's Avatar
I agree on the D44 open knuckle...
I took the frt. & rears out of a '79 K5 diesel and went with swapping both..
On the rear-end, I had to modify the spring pads a bit, as the '63 has a two inch narrower spring configuration......and I did have to swap & move the shock mounts on rear diff.'s.
However, the fronts were a straight swap. Easy deal.....no difference. I might add, though, that I took the opportunity to install a Saginaw P-steering box so I don't have a clue what you might run into on the pitman arm to drag-link connection.
Along with the aforementioned swaps, I also put a Hydro-boost on her, and I sure have to say that this rig never drove or stopped better. It sure does drive like a dream.
Just ask if you have any questions.
I added some pic's of the bracket engineering during installation.....(I have the GMC V-6 and couldn't find any pump brackets)....I don't have any shots of the diff. swaps handy, but I'll sure get some if you think it would benefit you any.
Let us know how it goes.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 03-20-2011, 03:07 PM   #14
A.T. RockDriller
I added some pic's of the before & after stance....The first ones were stock spring-packs, the second shows the way it sits now.
I added two springs on each side in the rear to address the rear end sag.
Les Hunter
