Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-19-2011, 02:22 PM   #1
HzEmall
HzEmall's Avatar
WTB - 77-79 Door Panel Trim
Looking for a really really nice set of door panel trim (not sure of the correct name) that goes around the wood or aluminum inserts.
If you have NOS I would love you long time
Tim Baillie
Installer/Designer/Fabricator
Trick Factory Customs
Company - www.trickfactory.com
Personal - www.hzemall.com
Instagram - @hzemall
HzEmall is offline   Reply With Quote
Old 02-20-2011, 05:39 PM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: WTB - 77-79 Door Panel Trim
Is it for Project C10?
I have an extra set but they aren't nice enough for it.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-20-2011, 09:48 PM   #3
HzEmall
HzEmall's Avatar
Can you post pictures or email them to me tim@rpmmediaprojects.com
Do they have all the studs on them?
Old 02-21-2011, 12:25 AM   #4
Gordonr1973
Home Built '87
I know they are missing some of the studs, but not all of them.
I'm out of town for work until March 4th, but if you still are looking I will take some photos. Just PM me to remind me then.
Gordon
Old 02-21-2011, 04:57 AM   #5
jlmerie
jlmerie's Avatar
Has anyone found a way to remove the speed nuts from the back of these without breaking the studs? I have tried to remove many of these and it seems the slightest pressure will twist the plastic studs. I have thought about trying to cut the speed nuts off, but then when you go to put the trim on the new panels the studs will just twist off then.
James
jlmerie is offline   Reply With Quote
Old 02-20-2011, 06:07 PM   #6
HzEmall
HzEmall's Avatar
It is for Project C-10
www.projectc10.com
Old 02-20-2011, 06:49 PM   #7
bigblock73
yeller
bigblock73's Avatar
67-72 interior, but 77-80 door panels?
I have a decent set as well, but likely not nice enough for the project. FWIW, there are two styles, one for panels with pull straps, and the other for panels without.
bigblock73 is offline   Reply With Quote
Old 02-20-2011, 08:19 PM   #8
BigRed76
BigRed76's Avatar
I would be interested in them if they aren't nice enough for HzEmall. I have a set and almost all of the plastic studs broke off when taking the panels apart.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-21-2011, 12:46 PM   #9
ECU PIRATE
ECU PIRATE's Avatar
Same thing happened to me (I have 3 sets). Saw a post on here awhile back about fixing this problem. I plan on drilling out some of them and expoxing in some small bolts and remounting them. Problem solved
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 02-20-2011, 09:48 PM   #10
HzEmall
HzEmall's Avatar
The style above in the picture.
Can you post some pictures of them? Do they have all the studs on them?
Old 02-21-2011, 01:25 PM   #11
hayesperformanceplus
Performance Shop Owner
hayesperformanceplus's Avatar
Even on original trucks with very low miles that have taken care of, the studs break off.
Because of the type and grade of plastic there made of, they will all was break unless you don't open and close your doors.
In solving this I always use in a number of spots a indoor/outdoor silicone/urethane
between the plastic door panel and the aluminum (78'-80') or wood grain trim (77') and then SMALL dabs in numerous places dead center on the back side of the chrome door trim you have pictured. You need to have the panel off and on a flat surface.
Tips:
- Be sure to clean the panel (behind where the trim goes too of course), trim and insert BEFORE doing this.
- Do NOT use a super strong silicone/urethane (Right Stuff, Liquid Nails, etc) because you'll have a Very hard time taking the trim apart (usually damage them) later if you need to and the regular indoor/outdoor silicone/urethane (eg. MONO Ultra) works great when full cured.
- Use clear silicone/urethane in case you can see a small speck between the panel and the trim when you look closely.
- I HIGHLY recommend using a "Water Clean Up" urethane because if you accidentally use too much you CAN quickly repair your mistake.
- Be sure to GENTLLY clamp the trim in place using LIGHT pressure and some clean, soft wood (balsa wood works great for clamping delicate trim), etc between the clamp and the trim, OR If you can't clamp it GENTLLY Hold down on the trim for a few minutes and then sit something that won't damage the trim on top till it cures.
You will find that when its done right you won't have trim moving ralling, flaping, or shifting around either and it holds perfectly in place. Also, you can never tell it has been done WHEN done correctly!
1980 GMC C25 Sierra Classic with 20,000 ORIGINAL MILES (32,000Km's) & Matching numbers
1977 GMC C35 Sierra Classic Crew Cab 454 A/C with 21,000 Miles & Matching numbers
1980 Chevrolet Silverado K20 400 4spd 4X4 74,000km's
1980 GMC C25 Sierra Classic CREW CAB, All Options, with 49,000 Miles
1979 GMC C15 Sierra Classic 454
1989 GMC R3500 CREW CAB
2003 Grand Prix GTP
1998 Regal GS
hayesperformanceplus is offline   Reply With Quote
Old 02-21-2011, 01:26 PM   #12
It has worked EXCELLENT on many trucks I restored...
2003 Grand Prix GTP
1998 Regal GS
Old 02-22-2011, 10:02 AM   #13
ScottW
Try Cheyenne Pickup Parts 405-872-3399, talk to Henry. They seem to have hard to find stuff. Nobody reproduces this style of trim, I bought a set of NOS CPP last year for my '77 C10. Good Luck
ScottW is offline   Reply With Quote
Old 02-22-2011, 11:23 PM   #14
HzEmall
HzEmall's Avatar
Where did you get yours?
Old 02-23-2011, 08:32 AM   #15
ScottW
I bought my set from Cheyenne Pickup Parts.
Old 02-23-2011, 11:47 AM   #16
How much?
2003 Grand Prix GTP
1998 Regal GS
Old 02-23-2011, 11:51 AM   #17
ScottW
400.00 i think.
Old 02-23-2011, 12:38 PM   #18
f.monroe
f.monroe's Avatar
I have a set on Ebay right now . Reserve is less than $400. They are Very rare so I priced mine so that it wouldnt upset me if they sell .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-23-2011, 07:03 PM   #19
CHROMAHOLIC
CHROMAHOLIC's Avatar
http://cgi.ebay.com/ebaymotors/NOS-G...item25618c3bb8
CHROMAHOLIC is offline   Reply With Quote
Old 05-08-2011, 04:24 PM   #20
I'm Selling my NOS Right Hand side one....
2003 Grand Prix GTP
1998 Regal GS
