02-20-2011, 01:13 AM | #1 |
Lower control arm....
Are the 2wd lower control arms all the same on the 67-72? I am not worried about the ball joints and cross shaft because i have new 1972 ones i will be installing. Truck and blazer are also the same correct?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
02-20-2011, 01:29 AM | #2 |
67-72 parts collector,…
Re: Lower control arm....
All the 67-72 1/2 control arms will interchange.
The 71-72 lower ball joint is different than the 67-70 lower ball joint. Also,... the 3/4 ton lower control arms are different. (the lower ball joint hole is a larger diameter)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-20-2011 at 01:29 AM. |
02-20-2011, 01:37 AM | #3 |
so, i can put a new 72 ball joint into any 2wd lca with no issues? Correct?
02-20-2011, 01:39 AM | #4 |
Yes,... into any 67-72 lower control arm.
(excluding the 3/4-ton version if your balljoints are for a 1/2-ton truck)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-20-2011 at 01:40 AM. |
02-20-2011, 02:19 AM | #5 |
thank you!! Now to start the search
