02-21-2011, 03:06 AM | #1 |
Removing a 2.2 crank???
How do I remove the triangle shaped piece from the crank that the crank pulley is bolted to, I can't pull the timing cover off without removing that triangle shaped piece first and I can't remove the crank with the timing cover on, any advice?
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet 1994 Buick Roadmaster 1994 GMC Sonoma |
02-21-2011, 12:57 PM | #2 |
Re: Removing a 2.2 crank???
Thats the balancer hub. You remove the balancer hub just like you do any regular harmonic balancer. You can go get a cheapy balancer puller tool and it will do the trick. Here is a pic out of GM service information.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
02-21-2011, 09:02 PM | #3 |
Thanks Spudz, now i can have a fresh block to play with.
02-22-2011, 10:15 AM | #4 |
no problem
Tags |
2.2, 4 cyl, crank, crank removal, rebuild |
