Old 02-21-2011, 05:51 PM   #1
JWNathan
700r4 with ECM, will they work with no carb?
Hey everyone, I tried searching but no such luck. My question is will my 700 still work after I removed my quadrajet?
Heres the back story, its an '83 C10 with a 305/700. I replaced my quad with a Edelbrock and swapped the dizzy for a vacuum advance HEI. Since I unplugged the carb sensors and the dizzy, will the ECM still lock up the converter? Thanks for any help!
-Jesse
JWNathan is offline   Reply With Quote
Old 02-21-2011, 05:59 PM   #2
MARKDTN
Re: 700r4 with ECM, will they work with no carb?
I may be wrong but I don't think the computer is involved here. I have an '83 K20 and mine only had a vacuum switch and the brake switch.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-21-2011, 07:45 PM   #3
psuedopimp
psuedopimp's Avatar
i can't say for sure how long my lockout has been disabled, but i have a sinking feeling that it has never been hooked up. i used to drive this thing as a daily from 99-06. my transmission is still going good.
i also have an aftermarket carb (600cfm holley). as soon as i get that connection cleaned out i will plug it back in and hopefully it works.
psuedopimp is offline   Reply With Quote
Old 02-22-2011, 12:05 AM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
that's the plus side of the 700R4 , it dont use a computer.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-22-2011, 01:01 PM   #5
Goldfinger
Goldfinger's Avatar
You can put any carburetor you want on it just make sure your tv is connected in the proper geometry.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 02-22-2011, 11:59 PM   #6
JWNathan
Awesome thanks guys! I was thinking it wasnt hooked up to the ECM but thought Id ask before I smoked something. Goldfinger, ya my TV cable is all hooked up and works good, I used the TCI bracket kit. Thanks again.
-Jesse
