Old 02-21-2011, 06:07 PM   #1
71AteLugger
71AteLugger's Avatar
Unhappy Transmission issues
Alright... I'm facing a trans rebuild I'm thinking. I have a 71 Chevy C-20 with 350/th350 combo. My issue is, my Tach is redlined nearly when I'm on the freeway... @65mph I'm hitting between 4000-4500 rpms... My fluids seems to be fine, however, this truck was abused before I got her and started bringing her back to life. I'm thinking the tranny might be shot, but it shifts well around town, but that third gear always leaves me expecting a gear is missing at high speeds. It has the power, but the trans is extremely limited. What are you guys running at on the freeway, and does what i'm talknig about sound like it's time to re-build? I'd hate to drop a grand to re-build right now, but I don't trust myself to do it. I have no experience re-building trannys so I'll leave it to the pros. thanks.
As for me and my Chevy, we serve the Lord.
Joshua 24:16
71AteLugger is offline   Reply With Quote
Old 02-21-2011, 06:25 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Transmission issues
[QUOTE=71AteLugger;4502877... My issue is, my Tach is redlined nearly when I'm on the freeway... @65mph I'm hitting between 4000-4500 rpms... .[/QUOTE]
What rear end do you have ? That rpm range does seem too high. I have a 373 rear end and I tach around 3200-3300 rpm at that speed.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 02-21-2011, 06:28 PM   #3
sameyrasmea72
Originally Posted by 71AteLugger View Post
I'd hate to drop a grand to re-build right now, but I don't trust myself to do it..
$1000 to build a th350? Maybe you need a new mechanic, I could get two built for that price.
72 Cheyenne Super
Old 02-21-2011, 07:00 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
Tire size and rearend gear would be valuable information. With 5.13 gears (highly unlikely, but not impossible), and a 28" rear tire @ 65 you'd be turning 4100 RPMs. I would also check your tach for accuracy.
I also agree that a grand for a TH350 rebuild is way out of line, should easily be able to get it done for half that.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-21-2011, 07:51 PM   #5
bosco200
bosco200's Avatar
I have 4.57s and id be pushing 4800 doing 65 mph thats why I drive 45mph every where.
bosco200 is offline   Reply With Quote
Old 02-21-2011, 11:15 PM   #6
71AteLugger
Living here in the Bayarea, Ca. every mechanic seems to think they can charge crazy prices... I changed the fluids, again, and added some lucas conditioner... still running great on the streets but once on the freeway, it is stuck at 4000... I'm leaning towards the rearend being the cause now, but here's a dumb question for you guys... how do I determine which gears I'm running? What's the re-build cost? My goal here is to have the ability to go 65-75 mph at around 2800-3200rpms... and not risk blowing something up.
Joshua 24:16
Old 02-22-2011, 12:01 AM   #7
cableguy0
Pull the cover off the rear. count the teeth on the ring and pinion gears. Divide the number of teeth on the ring gear by the number of teeth on the pinion gear. This is you gear ratio. All other methods are just a guess and not accurate. 2 quarts of fluid isnt that expensive.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-22-2011, 01:09 AM   #8
71AteLugger
Awesome... thanks for the info. I can't wait to see this truck really run!
Joshua 24:16
Old 02-22-2011, 02:58 AM   #9
mikie 1954
On mine the ratio was stamped on the side of the ring gear. I'am no authority on rear ends but I would think yours would be to. Mine is a 64 GMC with a dana 60 so maybe not the same marking?
mikie 1954 is offline   Reply With Quote
Old 02-22-2011, 05:47 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a grand... I can leterally get 4 rebuilds, with shift kit and converter for that much.
I also vote for your tach being way the heck off.
Old 02-22-2011, 01:37 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Here is a great article from Car Craft magazine on how to rebuild a TH350 yourself. http://www.carcraft.com/techarticles...oin/index.html
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-22-2011, 08:20 PM   #12
71AteLugger
I sure hope that it turns out to be only the tach... that would be sweet. It feels smooth up to that point, I just haven't taken it much further than 4500 because I wanted to keep my engine INSIDE THE TRUCK haha. I'll look into the rearend, I'm thinking that is most likely low gears causing the issue, not to mention the tach is original and not calibrated... thank you.
Joshua 24:16
