Old 02-22-2011, 06:08 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
NP208...possibly blown?
I was heading home today in my 6.2 diesel GMC, hubs still locked, in 2hi, going about 60. It started being bogged down and making bad bearing noise. I stopped at a gas station, pulled it into 4hi, backed up a foot, weent forward a foot, put it back in 2hi, unlocked the hubs, and it was fine. I got about 6 miles and as I pulled up to a stop light, the oise came back and I had no drive. no 2hi, no 4hi. I fought it into 4lo and drove another 2 miles [now on back roads], pulled over, got it into 2hi and got another 1,000 yds. and had to put it back in 4lo.
It's home now, I got it into 2hi, but only drove it forward and backward about 100 yds. each, it remained fine. Also when it was "in" 2hi but not moving, if I pushed as far forward on the lever as I could, it felt like trying to shift a Muncie into granny gear while moving, without the noise.
The truck has a 700R trans, 10-bolt open front, 10-bolt welded posi rear [welded because the govlock failed lol] and they're a 3:08 ratio.
Any diagnosis before I look into this?
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 02-22-2011, 10:53 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: NP208...possibly blown?
When was the last time you checked the fluid level? I have heard that 208 do not like to be ran low on fluid, it kills the pumps. I guess that was the major change in the 241, a better pickup design to prevent failures. Also, is your linkage working correctly underneith (not the lever but the rods under the floor)?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-23-2011, 01:25 AM   #3
Rogue_Alphonse
Haven't checked out anything on it yet underneath. The linkage is what I am HOPING it is. I took the truck out again earlier... drove about 4 miles and it was fine the whole time. I even pushed forward on the lever to see if it did the wierd-feeling thing it did before... it was fine. I'm beginning to think maybe the linkage is a little off. I'll crawl under it tomorrow and find out I guess...
Thanks for the help. I just figured SOMEONE has experienced a 208 blow before and would know the symptoms.
