02-24-2011, 12:40 AM | #1 |
How to install e.fan??
Hello everyone,
I have been trying to research the procedure on installing an electric fan on my 2002 silverado, but have not been lucky. My question is..... 1- Can I use the factory efan from a 05 silverado on my truck? 2- Will the efan have to be connected to the computer or will it pick up the signal from the temp. sensor and the AC relay? 3- What is your opinion about the flex-a-lite fans, and how much more does an efan increase in mpg? Your input is greatly appreciated, Thanks
Pick'em up, lay'em down, Oh Yeahhh Last edited by Bigo Serge; 02-24-2011 at 07:28 PM. Reason: added a question |
02-24-2011, 10:41 AM | #2 |
Truck Enthusiast
Re: How to install e.fan??
1- Yes you can use the ones from an '05, but you would also need the 34" radiator. you can pick up a set of ls1 or lt1 fans for your current setup and will work fine.
2-wire it in with a pair of relays, 1 relay per fan. you can use your own temp sensor if you buy one, doesn't need to tie into the computer 3-flex-a-lite makes very good fans, expensive though. ls1/ lt1 fans can be had for $100.00 or less
'85 swb |
02-24-2011, 07:30 PM | #3 |
Thanks DroppedGMC,
I'm going to look for a lt1 fan.
Pick'em up, lay'em down, Oh Yeahhh |
02-24-2011, 10:20 PM | #4 |
Truck Enthusiast
i'll post some pics up for you
'85 swb |
02-24-2011, 10:38 PM | #5 |
Has more rust than truck...
LS1 fans and zip ties.
02-25-2011, 01:21 AM | #6 |
Truck Enthusiast
^^ what mine looks like
'85 swb |
03-04-2011, 03:16 PM | #7 |
Did you notice an increase in gas mileage? Any problems with electric fans with towing?
1987 Chevy R10 2004 GMC Sierra 1980 Chevy Malibu |
03-04-2011, 11:52 PM | #8 |
About 1 mpg highway, no difference city. Never had any problems towing. I didn't tow much, but had no problems when I did.
03-06-2011, 07:27 PM | #9 |
Big Red - Now its a SWB!
What do you get the lt1 or ls1 fans off of. Camaro? What year? I want to do this to my tahoe.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
03-06-2011, 10:59 PM | #10 |
98-02 Camaro/Firebird with a LS1 engine. The older Camaro/Firebird with a LT1 efans will also work. I'm going to try to throw a "how to" together on this when I get time.
03-07-2011, 03:05 AM | #11 |
Thanks for the info, next time I go to the local junk yard I'll have to keep an eye out.
07-29-2012, 09:34 PM | #12 |
laying low
I just revisited this thread and wonder if you ever got around to the fan writeup? Thanks.
