02-24-2011, 12:57 AM | #1 |
1965 gmc frame motor mounts
Where can I find the correct pair of frame engine mounts for a 1989 350 with a 700 r4 installing into a 1965 gmc 1/2 ton swb. I have installed with mounts in the rear holes but, must have the incorrect mounts because the trans hits on the seam below the firewall and cannot install the HEI. Thanks,Jack
Posted via Mobile Device Last edited by N2TRUX; 02-24-2011 at 12:07 PM. |
02-24-2011, 01:49 AM | #2 |
60-66 Nut
Re: 1965 gmc frame motor mounts wanted
Those are the correct frame brackets for a small block in the '63-'66 trucks. Do you have the small hump trans cover? The HEI will fit.....it is close but it does fit. So it sounds like you are wanting a set of small block '67-'72 frame brackets?
02-24-2011, 01:50 AM | #3 |
From what your saying I am guessing you used the rear mounts from your old engine on the later model engine. What you need is the later model engine perches and mounts that mount closer to the front of the engine block. You can either run some out of 67 and newer truck or use aftermarket. CPP makes a nice tubular engine perch that's a direct bolt in and comes with hardware and is cost effective. With them you can run the later model engine mounts and it gives you more clearance for exhaust and what not.
02-24-2011, 01:57 AM | #4 |
60-66 Nut
The CPP tubular brackets utilize the '60's style passenger car motor mounts.
02-24-2011, 09:10 AM | #5 |
Will the small block 67-72 mounts line up in the front position with all holes? Ireally do not want to drill any holes. If I move forward to the front holes it appears the transmission will have clearance needed. It appeRs to have the small hump. Thanks for the help on this.
Posted via Mobile Device |
02-24-2011, 09:18 AM | #6 |
I just called the man I got my mounts from he advised they are from 67-72 truck.
02-24-2011, 10:23 AM | #7 |
sometimes one has to manipulate the floor seam that protrudes down from the floor at the b/housing area.. if you require new body mount insulators or if you have some rust in that area (cab mounts,floor), repairing the sheet metal in that area will also help to put the body back in it's proper position.
ron |
02-24-2011, 10:34 AM | #8 |
There are three holes on the top of your frame. The 60-66 stands use the back two holes and the 67-72 use the front two holes. Though the two perches look similar and will both bolt right up to your frame, the 67-72 have a tighter bend on the end that bolts to the crossmember. Sean
02-24-2011, 11:49 AM | #9 |
I recently used engine mounts from a 91 suburban (same as 87 pickup) we did use the front 2 holes in the frame but ended up having to modify the location of the rubber block (lower in the bracket) and we notched the frame to keep all dimensions the same as the suburban donor) it worked great and no interferance with the tbi 350 700r4 combo and the cab. Kieth
02-24-2011, 12:07 PM | #10 |
Happy to be here
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
02-24-2011, 10:26 PM | #11 |
I dont think anyone is trying to buy or sell anything via this thread. I thought he was just asking for a little info. Sean
02-25-2011, 12:22 AM | #12 |
Right?
02-28-2011, 05:38 PM | #13 |
I'm going to revive this thread with a few questions of my own. My 1966 C-20 came from the factory with a 283 andhigh transmission hump. I installed a 350 with an HEI distributor in place of the 283, and the clearance was tight, but manageable. While doing my frame-off I decided to use a set of 67-72 engine perches to move the engine forward 2.5 inches. This was relatively easy since I was installing a 700r4 and was going to be doing driveline modifications, trans crossmember relocation, etc anyway.
I've got the engine mounted with the new perches in place, Luckily, the difference in length between the Turbo 350 and 700r4 offset each other and my driveline is still the right length. However, my original dual exhaust won't fit. The stock ram's horn manifolds dump straight down over the front suspension crossmember, and the bend in the exhaust is too deep now. There is 6" of clearance between the bottom of the manifold and the crossmember. I went to a local custom exhaust shop today, and the owner told me that he most likely cannot bend exhaust to clear the suspension crossmember with my stock manifolds. He strongly recommended that I go back to my original engine mounting setup in the rear holes. I'm trying to figure out if he knows what he is talking about, or if he is just opinionated. If I move back to the original engine perches, the exhaust will clear, but the HEI will be tight, and some people have clearance trouble with the 700r4. If I stay in the forward location, I'll have trouble with the exhaust. My main question is: Do trucks that came from the factory with a high transmission hump have more HEI/700r4 clearance than trucks with a short hump? It seems like some people have trouble with clearance and some don't. I'm tempted to move the engine back, but then I will have to modify the driveline and deal with tight clearances on the distributor. I can't remember for sure how close it was before, but before I move it back, I want to make sure that the transmission will clear the firewall. Secondly, has anyone gotten exhaust to fit with stock manifolds and the engine in the forward perches? The exhaust guy says that he'll try to bend the exhaust to fit, but will make no guarantees. I'm open to suggestions, what do you think? |
02-28-2011, 07:08 PM | #14 |
700r4 have no problem with the h/hump
some people have trouble with everything. the hei should clear with the stock mounts, may be close but close only counts in horseshoes and hand grenades ron |
02-28-2011, 10:58 PM | #15 | |
Try this style it will make life easier, found on 69 and later 350 cars / trucks, plus what I `ve come to the conclusion is some people use differant trans mounts, ( height mounting position) which will dictate how close the disttributor or 700 r4 will reside at the body flange.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 02-28-2011 at 11:01 PM. |
