Old 02-24-2011, 03:03 AM   #1
Yukon 400
Hydroboost Adjustable Push Rod Solutions?
For those who have installed hydroboost brakes, I was wondering if anyone used units from an 88+ that had the fixed length push rod, and which method they got around the difference in length compared to the original bracket.
I was thinking about cutting the rod off where the body is straight, then cutting threads in and installing one of these threaded rod adjusters with a threaded clevis rod end.
I just wanted to see what kind of solutions have been derived for those who have already installed a hydrobooster setup, as I know that hydroboost is sensitive to push rod length and pedal travel do having adjustment will help in the initial setup.
Thanks,
Threaded Rod Adjuster
Clevis Rod End
Hydroboost Push Rod
1953 Chevy 6400 Truck - 2 Ton Pickup Project - 5.9 CTD, 6 Sp Allison, Air Ride, 22.5 Wheels
1952 Chevy 6400 Truck - Looking for a direction in life
Yukon 400 is offline   Reply With Quote
Old 02-24-2011, 03:39 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Hydroboost Adjustable Push Rod Solutions?
The way you described what you are planning is the way I did mine, except I didn't use that style of clevis, I used the original piece that was on the original rod that went to the master cylinder. Hydroboost works great, much better than a vacuum booster in my opinion.
ls1nova71 is offline   Reply With Quote
Old 03-24-2012, 11:54 AM   #3
AusTx68
AusTx68's Avatar
I know this thread is a little old but I figured someone might be interested in how it looks when it's done. I couldn't find a threaded adapter like you have pictured so I made my own. I used a 7/16x20 coupling nut and a length of rod threaded in 7/16x20. The original end of the hydroboost rod was cut off and the coupling nut welded into place. The rod was cut to length so my original 68' rod end would reach the pedal.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 03-24-2012, 01:34 PM   #4
woodwright
Enjoying left field
woodwright's Avatar
Something to keep in mind, the stock mounting point on the pedal might not be right for a newer style brake system. You need to make sure you're getting the right amount of movement for the master cylinder you're using. I'm useing a hydroboost from a 84 chevy truck with a diesel. I was able to just add a little material on the back of my pedal, and move my mount hole down a little. And I was able to move my peddle a little bit closer to the floor for more leg room.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-24-2012, 01:53 PM   #5
ls1nova71
ls1nova71's Avatar
I would be worried about the seal getting too hot when welding it, that's why I threaded mine and put c coupler on it. With something as important as brakes, I would want to be sure my weld was really hot to get good penetration.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
Old 03-24-2012, 05:38 PM   #6
AusTx68
AusTx68's Avatar
I was initially concerned about the heat. The guy that welded it made sure to keep it under control. It helps that the rod is crimped in place and moves freely.
Hey woodwright, it looks like you mounted it directly on the firewall. I plan to mount mine with with Captainfabs booster bracket. I think that will help with the angle but I will keep it in mind.
