Old 02-24-2011, 12:05 PM   #1
67_ShortFleet
67_ShortFleet's Avatar
Aftermarket door quality?
What is you opinion on aftermarket doors? Do they fit well?
Should I just reskin and repair what I have?
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 02-24-2011, 12:09 PM   #2
CC69Rat
CC69Rat's Avatar
Re: Aftermarket door quality?
My truck has AM doors on it and I'm pretty impressed with them. The fit is actually pretty good. I have no complaints. I believe they came from LMC but I'm not sure. They were on it when I bought it. They're just in primer now. I can post pictures if needed.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-24-2011, 12:49 PM   #3
Shane
Shane's Avatar
the common opinion around here is they suck ...
Shane is offline   Reply With Quote
Old 02-24-2011, 12:58 PM   #4
70cst
70cst's Avatar
I would agree. For the most part original metal is better than aftermarket as far as fit and quality. If I needed doors I would try and locate a good used set of doors. JMHO
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-24-2011, 01:10 PM   #5
bigo181979
Junior Member
bigo181979's Avatar
Use original doors if at all possible, its better to reskin one the mess with aftermarket... But as far as aftermarket goes I have had pretty good luck with the Goodmark stuff...
bigo181979 is offline   Reply With Quote
Old 02-24-2011, 07:33 PM   #6
CC69Rat
CC69Rat's Avatar
The PO installed the ones I have now, and I'm not about to take them off to put decent / marginal / re-skinned originals on. I have searched the world over for good GM metal for my truck where it was needed and paid top dollar for it but these are good enough IMO. I don't have a welder or the skill really to cut and re-skin original metal. So before I say 'They suck' .. I'm just saying I'm using AM because they're already on the truck. I have a decent set of originals I will sell if someone wants them.
Nothing about a 67-72 truck sucks in my opinion. I see tons of guys using aftermarket metal on their projects.. some good, some bad. LMC couldn't sell aftermarket metal, Year One, or anyone else for that matter if it sucked. They're making entire shells now.
For what it's worth, my aftermarket doors leave nothing to be desired. The fit and alignment is really good. I will use them and be proud to drive my truck. I'm sorry you guys haven't had better luck with them.
Chad
Old 02-24-2011, 09:09 PM   #7
Tim Christian
Tim Christian's Avatar
The NEW Key Part 67-71 Doors fit better than anyother door on the market and are even seven pounds heavier than Tri-Plus, LMC, Goodmark, and Counterparts doors.
Tim Christian is offline   Reply With Quote
Old 02-24-2011, 09:17 PM   #8
Spoof
Spoof's Avatar
I swear...if you found a nos door or fender, gave it to someone to install and told them it was aftermarket, they would spend days trying to install it so it fit perfectly. It would all in end in tears and racist comments.
It's bloody hard to install properly.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 02-24-2011, 09:59 PM   #9
CC69Rat
CC69Rat's Avatar
Chad
Old 02-24-2011, 10:34 PM   #10
Shane
Shane's Avatar
Old 02-24-2011, 11:04 PM   #11
trucks72
trucks72
trucks72's Avatar
It is a roll of the dice on all of them. No matter who makes them. I have installed a lot of them. Some of the skins are on wrong, some are to thick, but most had the post to high and had to be lowered. After you fit them and work on them awhile they work great.
trucks72 is offline   Reply With Quote
Old 02-25-2011, 12:36 AM   #12
Livrat
Member #1049
Livrat's Avatar
I too have installed alot of them.. and agree with the dice roll comment.. But then I have not seen the new Key Parts doors that Tim Christian spoke of.. Yet..
So fall all the repoductions I've installed have needed the drivers side window frame lowered at the rear. The passenger sides all fitted good, all the skins have been thinner than OEM.. but they are new, straight, not rusty and fit fairly well.
On a funny note I have a 72 Cheyenne Super in the shop that needed a drivers door, and the customer insisted on NOS.. so I found him one to the tune of $900, and it fits horrible.. the window frame was way out of whack, I could litterally put my fingers between the top of the frame and cab.. I couldn't drill out the welds and reposition by lifting it up, the curve was way off, Still had to cut it apart and take a window frame off of another door and fit to the NOS one!!
So much for the "NOS is better" theory!! Its still a roll of the dice.
I could of bought 3 reproductions for the price of one NOS door.. Oh well "the customer is alway right"
Livrat is offline   Reply With Quote
Old 02-24-2011, 11:42 PM   #13
AusTx68
AusTx68's Avatar
As trucks72 said, it's a roll of the dice. If you are cool with possibly losing $700+ or don't mind bad door gaps then go for it. I gambled and lost out. I ended up with garbage. After many hours of work they had to go. I later found a set of original doors and they fit like a glove.
Functionally, aftermarket doors will work but if fit and finish are high on your list, don't even waste your time.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 02-24-2011, 11:56 PM   #14
70chevymanshort
Has anyone done door skins? If anyone has what are the best skins to use and are they difficult to put on?
70chevymanshort is offline   Reply With Quote
Old 02-25-2011, 12:02 AM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
I hate the ones on my truck (tri plus) bought around 2005.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
