Old 02-24-2011, 12:21 PM   #1
dbcox
dbcox's Avatar
body part swap
i got a 1980 2wd chevy. I want to change the front out to the 89-90 dual headlights like a blazer. I know it can be done on 81 ithink and up to 87.
My question is since everything on this one needs replacing, if i buy parts for say an 86 will it work on the 80? If i get the new hood, new cowl, hood hinges, inner fenders and fenders will all that match up so i can order the parts for the grill swap? radiator support will of course be for the blazer, looks like the 89 crew cab grill was the same as the blazers too. thanks
www.lubedealer.com/dbcox
ZO#1568374
dbcox is offline   Reply With Quote
Old 02-24-2011, 12:45 PM   #2
80stepsideguy
Laid back freak
80stepsideguy's Avatar
Re: body part swap
Your swap will work, you`ll have to modify the front frame horns for the 81-7 front clip.Also keep in mind you`ll have to use the 81-7 wiper arm assembly under the cowl cause the 73-80 arms are shorter cause it doesn`t require the cowl panel.Other than that it should be a easy swap.Also you`ll have to cut some holes in the cowl for the hood hinges too..
thanks
Pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
Old 02-24-2011, 12:47 PM   #3
dbcox
dbcox's Avatar
Re: body part swap
I was wondering about the wipers and the cowl. One thing i wasnt sure about was the top of the fenders where they meet the cab.
Thanks for the onfo
ZO#1568374
Old 02-24-2011, 04:08 PM   #4
Sarge261
Sarge261's Avatar
Re: body part swap
thanks
Pat
Pat,
What do you have to modify on the frame horns. I have a 76 frame I'm going to put a 86 body on with a 91 front clip...just curious.
Sarge
1997 GMC Yukon
Western Mid Weight Plow
Project THOR
Sarge261 is offline   Reply With Quote
Old 02-24-2011, 12:59 PM   #5
Jonboy
Slots go on anything!
Re: body part swap
The fenders will bolt right up. 80 Stepside was right on.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-24-2011, 01:40 PM   #6
SeanPaintsFlames
SeanPaintsFlames's Avatar
Re: body part swap
Where in Ga are you? Do you have a newer front end already?
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
