02-24-2011, 04:22 PM | #1 |
Brakes lock up only when it rains...
It's a 72 Shortbed Stepside, front disc, 250 six, 3 speed. I added power brakes (CPP booster and M/C) and now it locks up with the slightest touch when it's raining. Drives and stops fine in all other conditions.
Any ideas why this is happening? Any help would be greatly appreciated.
Beauty is in the eye of the beer-holder. Praise the lowered! |
02-24-2011, 04:25 PM | #2 |
Re: Brakes lock up only when it rains...
Here's a couple pics of before and after the swap...
02-24-2011, 04:26 PM | #3 |
Member
What's locking up front or back? And have you ever replaced all rubber brake lines? also, see hot your brakes get next time your driving around, i bet they're dragging a little bit all the time
02-24-2011, 04:28 PM | #4 |
I'm pretty sure it's the rear.
02-24-2011, 04:34 PM | #5 |
Member
if you haven't yet, replace the rubber brake line that goes around the rear end. They have a tendency to swell shut over time and act like a check-value
02-25-2011, 01:54 PM | #6 |
I haven't replaced any of the rubber lines. I'll give it a shot. Thanks for the info. What elso could be causing them to drag?
Beauty is in the eye of the beer-holder. Praise the lowered! Last edited by dabruce15; 02-25-2011 at 01:55 PM. |
02-25-2011, 02:11 PM | #7 |
Old Skool Club
First thing...disc brakes will always have a slight "drag", in that it's just what they do. However, it won't be a drag in the same sense as a shoe-type brake that doesn't release completely.
As to what it is that can make a brake drag: As suggested, a flexible (rubber) hose that has collapsed internally will restrict the out-flow of the brake fluid as the brake shoes (or disc brake pads) retract after use. Anything that may have leaked onto the shoes. If you have a grease seal in the rear that is leaking, or if your wheel cylinder is leaking slightly, then anything that accumulates on the lining can make it grab. Weak hardware (springs, etc.) may not allow the shoes to retract completely. If so, and the shoe(s) drag, they could be premature in their braking action. Drums that have been cut (turned) unequally from one side in comparison to the other. If the diameters are not identical, or nearly so, then one side will brake more than the other. Trust me on this one....been there. Not pretty. Your proportioning valve may not be doing its' job. After all, it's at least 39 years old. Wait for some dry weather, then take it out somewhere that doesn't have any vehicular traffic, like an abandoned mall. You get the idea. Then, start locking up your brakes to see which one it actually is, if you don't already know. Once you know for sure which wheel is locking, then you'll know where to start.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 02-25-2011 at 02:11 PM. |
02-25-2011, 02:16 PM | #8 |
pump the brakes instead of just slammin them to the floor you stoping distance will decrease
02-25-2011, 02:20 PM | #9 | |
Second Chance Program
02-24-2011, 04:44 PM | #10 |
My 2003 GMC Sonoma does this. I'm pretty sure either the metalic brake pads or the front discs are flash rusting in the rain and greatly increasing the coefficient of friction. At speeds below about 15, if you lightly touch the brakes, it stops the truck dead in its tracks. I'll normally lightly apply the brakes with my left foot while the truck is under power to clean and dry them. Once I do that they're fine.
Dave 1971 Chevy K10 1972 Chevy C10 |
02-25-2011, 03:05 PM | #11 |
I only see one brake line coming from your new master???
02-25-2011, 03:12 PM | #12 |
There is two. The one you can see in that picture is the one I replaced that I broke when removing the old one. The other one can barely be seen because it's covered in "age".
