Old 02-25-2011, 11:58 AM   #1
custom1970
Member
custom1970's Avatar
Help with Holley fuel leak
I was hoping someone could tell them me how to fix a small fuel leak, this is not my actual carb, just one close to it. I have a small amount of fuel leaking from around the small (approx. 3/8") disc i've circled in the pic. I just re-installed the carb. after having it re-built and have a call into the shop (in NJ) but usually takes a day or two for them to call back. I was hoping there might be an easy fix i could do this weekend so i don't have to ship it back to them...., Any help would be appreciated, thanks
oh, other than the small leak, it ran great
custom1970 is offline   Reply With Quote
Old 02-25-2011, 12:24 PM   #2
Fitz
Re: Help with Holley fuel leak
This core plug is installed from the factory and isn't meant to be removed.
You can seal it with JB Water Weld epoxy.
Fitz is offline   Reply With Quote
Old 02-25-2011, 02:17 PM   #3
custom1970
Member
custom1970's Avatar
update, carb shop called and said same thing, fix with JB Weld, thanks
Old 02-28-2011, 02:06 PM   #4
Fitz
Carb shop probably removed it during rebuild...some idiots should stick to sewing or gardening.
Old 02-25-2011, 12:40 PM   #5
custom1970
Member
custom1970's Avatar
ok, i'll try that. Mines a little different than the photo, mine does not have the stainless ring around it, the housing is kinda bent down slightly holding the plug in. looks like they removed both of them during the rebuild, but maybe not.
thanks, it's amazing what you can fix with JB weld
