meowMEOWmeowMEOW
LQ4 quick disconnects
I was trying to search the FAQ on LS swaps; I could have sworn a page had fitting sizes on it. I'm trying to find the quick disconnect sizes on the fuel rail (integrated fpr) on the lq4 (2003) with the return system.
I think one is 3/8 and the other is 5/16ths but can't remember, and need to order some parts. If anyone knows what size they used, let me know. Thanks/
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Aug 2004
Re: LQ4 quick disconnects
I thunk they were AN fittings, but I checked on performance trucks.com and ls1tech and all I find are what you already know or said.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 02-25-2011 at 05:12 PM. |
meowMEOWmeowMEOW
they are def quick connects (an's would be an aftermarket rail). I took a look on ls1tech too, but its too f-body oriented for me to find lq pertinent information some times.
I used AN fittings at my rails. there is also some that have the quick disconnects and an AN fitting on the back, Jeggs and Summit sell them, I think they are from Russel.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Supply is 3/8", Return is 5/16". Or -6 & -5 if your going AN.
meowMEOWmeowMEOW
^aha thank you sir!
I assume the fitting you are after is the same one that I'll be needing for my setup. If so, they can be had in a couple different colors and usually have a -6an male fitting.
For the 3/8": Jegs 555-103101 black Russell 640853 black Russell 640850 blue For 5/16": Jegs 555-103100 black Russell 640863 black Russell 640860 blue
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
meowMEOWmeowMEOW
Pretty much, although the ones I was looking at were the Russel with the barbed ends. Summit has them in regular black.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 02-27-2011 at 02:33 PM. |
