Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-28-2011, 12:20 AM   #1
d.garza9
d.garza9's Avatar
72' 5.3-4l60-np205
Okay Folks here's the deal. Bought a 72 blazer to make it a daily driver. I purchased the engine(5.3) and tranny(4l60e) last week for $1000 even. I thought it was a heck of a deal too! My issue now is tying everything togetherwhile keeping the original np205 transfer case. At this time I'm getting ready to purchase the advanced adapters shaft http://http://www.advanceadapters.com/products/pn-50-6900/
and the 4l60e kit
http://www.advanceadapters.com/products/pn-50-0405e/
Please let me know if there's anything I'm missing. Also I've been advised that will need to lift the truck 3 to 4 inches to create clearance from the front differential. I have also been advised that the engine will have to moved 2 inches to the front to keep the original shifter in its place.
Thanks in advance!
d.garza9 is offline   Reply With Quote
Old 02-28-2011, 06:50 PM   #2
thor
thor's Avatar
Re: 72' 5.3-4l60-np205
I have a 350, 700R4, NP205 combo in my 72 blazer. I bought my tranny from a coworker who had it BUILT. The tranny had the output shaft you listed to make it "look" like the TH350 it was replacing. Then using the stock Th350-NP205 adapter it bolted right-up. I chose to use the factory 350 location, then bolt-on the tranny, then bolt-on the transfer case, then bolt-on the crossmember. This gave me locations to drill new holes. I then cut my tranny cover for the new shifter location. This was about 2" towards the rear; from what I read the actual measurement is 1-7/8" but I think it's always better to mock-up. So, if you wanted the shifter in the stock position I would agree that the engine would need to move forward ~2". Not sure about front diff clearance though. Something to think about.
I understand that with the 4L60e you need to have the adapter with reluctor wheel for the VSS. However, reading AA site you attached, I am unsure if this will add length to the end of the 4L60e. As a follow-up question you might want to pose to AA, will this negate the need for the new output shaft? Could save you some bucks and a rebuild. Then again, if you do need the new output shaft, you can also beef-up other components that break inside the 4L60e.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 03-02-2011, 01:08 AM   #3
themb2g
i am doing this exact same thing and am joining this thread for the advanced adapters links since they just changed their website. I have already ordered a 2" lift, and now i am wondering if it is going to be enough to fit everything in. Where did you read that you need a 4"? thanks!
themb2g is offline   Reply With Quote
Old 03-02-2011, 04:34 PM   #4
d.garza9
d.garza9's Avatar
I got the information from "The Alien" on this web site. He has a great Mating a 4l60 to NP205 thread. It provided me with most of the information I have and think I will need. I was just searching for other opinions and possible solutions. Let me know if you come across something.
Old 03-09-2011, 02:24 PM   #5
d.garza9
d.garza9's Avatar
here are some of my pics
Old 09-29-2011, 11:59 AM   #6
Gunny Davis
Doing the exact same Swap...
AA fails to tell you that you need to have the NP205-TH350 adapter and sleeve machined to fit thier 4-6 bolt adapter for the 4L60e. It is a *note in the instructions you can see on thier website for Part AA50-0405.
My T/C adapter had the bearing style sleeve. Remove the bearing and have .500 removed from Trans side. Don't forget to have the chamfer re-ground on the inside of the sleeve to assist with fitting the Trans shaft in there.
I hope to have this done today and I'll post pics
Gunny Davis is offline   Reply With Quote
Old 10-17-2011, 09:14 PM   #7
Jtrux
I'm a poor spectator
Jtrux's Avatar
Where are you located? I'm doing a similar swap. 6.0/sm465/np205 into my 71.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-26-2012, 02:54 PM   #8
lopemaxx
lopemaxx's Avatar
garza
did you complete the swap? what did you end up having to do to mate the 4l60e to the np 205?
thanks
70 Chevelle SS (clone), 454, 350 auto
71 K5 350, 350 auto, 3" body lift, 35's
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |____|__|___]
*.*..*.*.._@_ _ _ _ @
lopemaxx is offline   Reply With Quote
