Old 03-02-2011, 12:42 PM   #1
Roadmarks
Roadmarks's Avatar
Yet Another Dip Stick Question . . .
Howdy, When I installed power brakes on my '71, I never considered the dip
stick. It is now basically under the master cylinder. It is inconvenient to get to.
I can live with it as it is, but is there a good way to bend, lengthen, replace, etc. the stick and tube to make it easier to reach? My truck is a 1971 c-10, 350/350. Thanks in advance for any options.
Best wishes,
Les
Roadmarks is offline   Reply With Quote
Old 03-02-2011, 12:57 PM   #2
1low
Re: Yet Another Dip Stick Question . . .
A flexable tube from lokar might work. or u might be able to get a shorter tube/dipstick
1low is offline   Reply With Quote
Old 03-02-2011, 01:09 PM   #3
Hardesty454
Hardesty454's Avatar
my stick is on the opposite side, change your pan or there are felx wire tubes that would be alot cheaper for you.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 03-02-2011, 01:41 PM   #4
cdowns
cdowns's Avatar
that is a different year motor you need to change the block as well as the pan
Old 03-02-2011, 01:45 PM   #5
Boog
laying low
Boog's Avatar
I believe the trucks came with dip sticks on the passenger side and cars and vans came with it on the drivers side.
What you might look into is using the stick and tube from an 88 and later truck. It is longer and bends toward the front of the engine thereby maybe clearing your booster.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-02-2011, 02:00 PM   #6
Hardesty454
Yea, I have a bog block out of a 74-75 truck. Either way there is a LONG time between block style changes so that shouldnt matter too much. If I were in your situation, Id go with the Flex tube.
Rob
Old 03-02-2011, 03:17 PM   #7
hotrodimpy
Roadmarks, I noticed you did say 350. 1979 and earlier small blocks had the dipsticks on the driverside of the motor. The Lokar dipstick for that application is part # ED-5002 There will not be much flexabilty on that unit because the flexible housing is so short. It is defiantly better than the stock unit if you want to change the angle. Any questions contact us at lokar Toll Free 877-469-7440. Thank you John
hotrodimpy is offline   Reply With Quote
Old 03-02-2011, 04:28 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If you can find a dipstick & tube setup from a 4x4 -- they are longer, and extend forward... well clear of the master cylinder.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
