Old 03-02-2011, 12:44 PM   #1
65stepside
65stepside's Avatar
60 clutch/brake master cylinder to 65 brake master cylinder question
Ok So I am cab swaping.....I think I have most everything figured out except the brake master cylinder. The 60 keeper cab has the hydraulic clutch and brake master. The 65 just has the brake master cylinder. I have an automatic in the keeper truck, so no need for the clutch. Question is, can I take the brake master cylinder off the 65 cab and mount it up to the 60 and still work without a whole lot of modifying? probably just redrilling holes, just wondering the ease of this or if it a whole separate project in itself?
thanks !
J
1930 Olds 5 Window Coupe
1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350
1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!"
1966 Toronado
1971 Cutlass
1972 442
1978 Chevy 1/2 Long Fleetside
2001 Dodge 2500
65stepside is offline   Reply With Quote
Old 03-02-2011, 05:02 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 60 clutch/brake master cylinder to 65 brake master cylinder question
this thread might help, check out the last post too, you might need to do some modifying..
http://67-72chevytrucks.com/vboard/s...d.php?t=355711
Old 03-02-2011, 07:39 PM   #3
jbgroby
jbgroby's Avatar
thanks !
J
Contact Capt. Fab.
He makes this part which I installed just 2 days ago, to cover the 2nd. hole and re align the bolts.
jbgroby is offline   Reply With Quote
Old 03-03-2011, 10:37 AM   #4
65stepside
65stepside's Avatar
Sweet thanks !!!!! Are you using the original brake cylinder from a 63-66?
1966 Toronado
1971 Cutlass
1972 442
2001 Dodge 2500
Old 03-04-2011, 11:14 PM   #5
jbgroby
jbgroby's Avatar
No, my donar cab was set up as a 4 speed so since I had the hrdramatic mated to the block, I needed to close off the extra hole. on the BB they say use a '67 impala? dual master cylinder whoch mates right up the original holes.
Someone chime in on what years he can use, I'm not sure.
jake
Old 03-05-2011, 01:03 AM   #6
Captainfab
60-66 Nut
Most any GM master cylinder will bolt up. For manual drum/drum brakes I prefer to use the '67-'70 master cylinder and metering block. For manual disc/drum brakes , use a '71-~'76 master cylinder and proportioning valve.
jake
