Old 03-02-2011, 02:38 PM   #1
**grumpy**
**grumpy**'s Avatar
Couple rearend swap questions/brakes etc
I have a 72 12-bolt 3.08 rear to swap into my 66 short fleet.
I know the 72 is 3/4" wider on each side, which is fine.
I dont have any backing plates or brakes on the 72 rear. Will the backing plates and brakes work from the 66 rear?
Also, I ordered a bolt-in cnotch from cpp, and their super trac-bar. I was going to order the 1 1/2 or 2" drop block/ubolt kit, but 70 bucks plus shp seems extreme.
I can make steel blocks for zero, and just need Ubolts. So anyone know where to buy reasonable Ubolts, or can anyone give me measurements so I can have them made local??
Thanks fella's
Road Hounds
**grumpy** is offline   Reply With Quote
Old 03-02-2011, 03:06 PM   #2
Heater63
Heater63's Avatar
Re: Couple rearend swap questions/brakes etc
Ubolts -I've seen this solved here on this board, so search the archives.
I would also try a tractor supply, big truck shop, or maybe online like stengelbros or fastenal or McMaster-Carr
292 + TKO500
Heater63 is offline   Reply With Quote
Old 03-02-2011, 03:15 PM   #3
SFTorange
SFTorange's Avatar
Your brake backing plates will work just fine. I believe truck 12 bolt backing plates will fit from any year. I just completed the swap to the HD 11 5/32 X 2-3/4 brakes by swapping backing plates from a late 70's K-10.
SFTorange is offline   Reply With Quote
Old 03-04-2011, 02:03 PM   #4
**grumpy**
**grumpy**'s Avatar
Thanks guys.
I know the axle housing is 3", but anyone know how long I should make them to use a 2" block? 11" ?
Also, since my truck is buried and I cant get to it, and Im having a brain fart, what size thread are the ubolts for trailing arm rearends? So I can tell the shop Im having make them. I know theyre alot more stout than a typical ubolt.
Road Hounds
Old 03-04-2011, 05:01 PM   #5
SCOTI
SCOTI's Avatar
Originally Posted by **grumpy** View Post
Thanks guys.
I took a stock one w/me to a local spring shop & told them I need some 2" longer. He measured & bent me some new one's. I believe they're 3/4" diameter.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-04-2011, 03:05 PM   #6
Clyde65
Clyde65's Avatar
here are some from CPP, extended length. you might ask Jeff from CPP and see how long they are.
http://www.classicperform.com/Store/...k/6072RUBS.htm
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
