03-04-2011, 11:30 AM | #1 |
1960-66 Door Rebuild / Paint Sequence
Hoping you guys could help. What is the proper sequence of events when it comes to painting doors in regards to installing new door felts and weather stripping?
I assume:
Thanks, John Last edited by lakeroadster; 03-04-2011 at 11:30 AM. |
03-04-2011, 12:03 PM | #2 |
Re: 1960-66 Door Rebuild / Paint Sequence
You can do the felt with the door off or on. But that sounds about right either way. I am not pulling my doors, but I will prime/paint before I install new gear.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
03-04-2011, 01:29 PM | #3 |
Resistance is Futile
Good question, John. I've always been curious where the exterior and interior color meets.
I think I would risk the scratches and install the vent after paint.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-04-2011, 01:51 PM | #4 | |
She's destined to be a beater... but I do want new rubber and felts due to the rattling. As I keep saying to myself, stay focused and remember the phrase: "That's good enough" Last edited by lakeroadster; 03-04-2011 at 01:53 PM. |
03-04-2011, 05:23 PM | #5 |
If you are replace everything in the window you will have to remove the wing vent first to get the window out, I would paint it with everything out and then put it back together. JMO Kieth
http://kieth.smugmug.com/Trucks/66-G...99080999_gg4ix |
03-04-2011, 05:37 PM | #6 | |
Go figure....... Last edited by lakeroadster; 03-04-2011 at 05:39 PM. |
03-04-2011, 06:14 PM | #7 |
John to each his own but have read here on a coupe of threads where the builder has assembled the doors on a bench or table top which they had said made it much easier, can you patina the window area first then install felts, cranks and window then hang door?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
03-04-2011, 06:23 PM | #8 | |
Thanks, John |
03-04-2011, 10:50 PM | #9 |
I painted mine totally dissasembled and off the truck. Let the paint cure so that it doesnt chip easily and put masking tape along the edges before re assembly, this will help to prevent scratches and chips. Hang your door and install your felts/weather stripping and glass. I have also painted the jams and then hung the doors before painting the outside. You then have a paint line on the jam but it isn't easy to see.
