03-04-2011, 08:03 PM | #1 |
Holly Red Fuel pump
Im moving things around on my 70 (fuel lines) and want to move the pump as well. It is currently mounted on the fender wall and I want to move it somewhere it wont be seen. Does anyone have any ideas where the best location would be? Should it be closer to the tank (currently origonal) or the carb?
Also, pictures of mount set up is appreciated.
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
03-04-2011, 09:58 PM | #2 |
Re: Holly Red Fuel pump
Electric pump? As close to the gas tank as you can get.
03-04-2011, 10:41 PM | #3 |
03-04-2011, 10:53 PM | #4 | |
Thats what I was thinking...
Can I run it along the frame rail (which is real close to my exhaust)? I don't feel as if that would be the safest place for it.
03-04-2011, 11:28 PM | #5 |
I run a Holley red pump, and have it mounted to the frame below the in cab gas tank. No issues, and my truck lays frame. I do however have it mounted to the outside of the framerail, and my exhaust is ran inside the frame rails. Don't expect it to be quiet as a church mouse though, those pumps are loud no matter where you put them.
03-05-2011, 12:03 AM | #6 |
Mine was mounted on the frame about a foot from the back of the frame rail about 9in from my fuel cell. Worked amazing, just be sure to put some kind of rubber insulator between it and the frame rail otherwise it resonates the humming sound thru the truck
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
03-05-2011, 06:06 PM | #7 |
awesome... (mounted and wired it last night, just got to try it out today.
