03-04-2011, 11:06 PM | #1 |
Rear springs compressed, advice?
This was obviously somebody's attempt to lower the rear end. Should I remove these? If so any tricks? Thanks.
03-04-2011, 11:26 PM | #2 |
Hand Crafted C-10
Re: Rear springs compressed, advice?
Kidd, movin' ya to suspension to the gurus.
03-04-2011, 11:31 PM | #3 |
Moderator
I would just take a cut-off wheel to that contraption. Protect your eyes and hands and you should be fine, the spring itself is restrained and not fully compressed.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-04-2011, 11:36 PM | #4 |
67-72 parts collector,…
Definitely remove them.
If you still want the lowered ride height,... add a quality set of drop springs. While your at it,... trim those u-bolts.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-04-2011 at 11:36 PM. |
03-04-2011, 11:51 PM | #5 |
Trim the U-bolts??? I always wondered why they were sooo long, but just figured thats the way it is... Think those u-bolts were replaced at some point?
03-04-2011, 11:59 PM | #6 |
Yes.
Trim off any part of the u-bolt that extends past the nut.
03-05-2011, 01:42 PM | #7 | |
If you plan on getting some lowering blocks those U-bolts would work well.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
03-05-2011, 02:18 PM | #8 |
Any recomndations on good lowering blocks? I may just add some...
71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
03-05-2011, 02:35 PM | #9 | |
http://www.stockcarproducts.com/trkarm1.htm Many suspension vendors also sell them. CPP, Performance Online, etc.
03-05-2011, 01:00 AM | #10 |
its all about the +6 inches
actually, someone was trying to LIFT the rear. Those 3 center coils are supposed to be almost on top of heach other, like they are on the oposite side of the coil.
Remove the spreaders, leave them there, you'll never notice them untill you look under again. In theory they stress the spring where they are spread apart, but theory isn't reality. |
03-05-2011, 11:44 AM | #11 | |
Why are the coils supposed to be on top of each other? I would think having space between them would allow for better smoother compression when bouncing on bumpy roads. Its physics and I'm no major, but any insight? |
03-05-2011, 12:22 PM | #12 |
those look like spring clamps to me.....clamping together lowers the truck.....to lift it they made the spring spacer that u turned inbetween the coils with a 1/2 breaker bar...anyways remove the clamps (i would unbolt them) and buy some lowering blocks if u want it to be a little lower......goes in between the axle pad and trailing arm....it will use up the rest of the threads on the bolts and u will still have a decent ride..
03-05-2011, 03:51 PM | #13 |
tryin to wack those things off with a cutoff wheel could cause you bodily harm and bloodshed
two of the proper sized wrenches and some pbblaster wood b my choice better safe than sorry back in the 60's-70's those type of thing were sold to lower coil springs//sold at pepboys jcwhitney strauss stores i thing they even had them in the sears catalogue
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-05-2011 at 04:14 PM. |
03-05-2011, 04:47 PM | #14 | |
08-24-2011, 10:53 PM | #15 |
Well I finally removed them; nuts came off easy for the most part. Pneumatic impact did its job. 2 of the threaded rods were bent and had to resort to my sawzall; that made quick work of it. thanks for the input.
