03-05-2011, 04:44 PM | #1 |
Battery and cable questions
It's battery time and I'm trying to figure out what battery I want for my '71. I bought this truck new and at some point I changed the factory side terminal cable ends to top post (can't remember why). What kind of battery is in your truck, or what kind do you recommend? Would you leave the cables like they are, or replace them with new side terminal cables? I'm in the process of a light restoration. Your help is greatly appreciated.
Eddie |
03-05-2011, 04:46 PM | #2 |
Re: Battery and cable questions
Buy an optima red top battery and it has top and side posts so you wont have to do anything but swap the battery.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
03-05-2011, 07:14 PM | #3 |
My '69 has had top terminals from day one. I believe the '71s came that way also. As I recall top terminals came along later.
03-05-2011, 11:12 PM | #4 |
its all about the +6 inches
71 was the first year for side post batteries in all GM vehicles.
03-05-2011, 11:17 PM | #5 |
Old Skool Club
You probably changed to top posts because you preferred them. As I recall, we didn't especially like the side terminals. The were not what we were used to using. Jumper cables didn't hook up very well. The bolts that held the cable ends to the battery, didn't seem very capable. Corrosion built up between the cable ends and the battery terminals and cleaning them was more involved that taking the old brush that fit down onto the top terminal and got clean with a couple of spins.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-05-2011, 11:27 PM | #6 |
Junior Member
I guess battery brands are a personal preference. Some don't like Interstate batteries, but I have had one in my '71 for over 5 years now and it works great.
I always buy the one with the most cold cranking amps I can that will fit with the longest warranty I can afford. Also I normally buy a dual terminal battery so it can be used in different vehicles. Living on a farm I some times have to move a battery from one vehicle or other. My son likes Bosch or Duralast Gold. My brother swears by Die Hards. Like I said it depends on what brand you like.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
03-05-2011, 11:40 PM | #7 |
WARRANTY'SS BLA..
your just paying for a bet.. a 575 cca battery with a 2 year warranty is the same battery as the 575cca with4 or 5 year waranty just a different lable on the outside.. |
03-06-2011, 12:22 AM | #8 |
I've seen side terminals with stripped threads, so I never liked them.
Decide on the terminal orientation, meaning which side the + and - terminals are on, and measure the battery box. Then buy the biggest battery with the most CCA that fits in the box with the right orientation. Maybe it's strange, but that's my battery buying strategy... |
03-06-2011, 12:46 AM | #9 |
It really depends on what size engine you have. If youre pushing a larger engine youre going to want a larger CCA. Honestly, I run optima 800-1000 cca on everything (small block/ big block). Keep in mind battery size and amp size matter as well. You dont want a battery thats too big or small for your alt.
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
03-06-2011, 04:03 AM | #10 |
Big Red - Now its a SWB!
I run the walmart brand batteries just because they swap them out for warranty no problem and don't even check them. So what I do is watch the date on the batt. and when it gets close to the exp. date I take it in and swap it out, then the warranty starts over again. They don't even require a receipt, they just go by the sticker that has the date of manufacture on it. I've had good luck with them, I think I've only had one that failed on me before the warranty was up and that was because I ran it dead multiple times.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
03-06-2011, 09:54 AM | #11 |
I appreciate all of the replies. I bought this 71 new. It came with a Delco battery that had the eye in one of the caps. Cables were definitely side post. I think that I changed the cable ends for all the reasons that ChevLoRay said. I was toying with the idea of putting the side post cables back on this truck as I restore it, but after reading the replies to this thread, I think I'll stick with the top post.
I'm really giving some thought to the Optima red top battery. Right now the truck still has the stock 350 with 83,284 original miles on it. I do plan to massage it a little, nothing radical. It does have factory air, but no high power after market electronics. Eddie |
