Old 03-05-2011, 06:01 PM   #1
jasonroman
jasonroman's Avatar
back to old timing issue.
at around 800 rpm, might have been neer the 12 mark.
but then when i shut truck off, i end up with lots of pre ignition.
prior to me messing with things today, think i was around 24-28 on timing light.
took off distributor to change the oil pressure sending uint, to see if i have issues there.
then when i put it back i figured i was not exactley where i was before. so i played with timing and my rpm. just installed a tach last week.
timing light says 800 tach says 7iish....
at one point i had it at the 12 ish number i thought i read somewhere...starting point. around 12?
so when i was around the 12 ish area, and at around 760 rpm.
had a bit of fire under hood from time to time and when id shut truck off, lots of over run/ pre ignition i think its called.
id like to know what i need to do to dial in.
my adjustments came from moving distributor in different directions and getting different responses.
again, i had an 82 with a 350, intake carb, headers....
id get on gas and lay wheels for a good distance.
this 85... if i get on it too hard, truck will shut off.....
and only when i hit a corner and get on it do i notice a bit of reaction
but i also hear more noise than id like coming from the rear end.
so lots off bla bla bla on my end.
any of you guys able to help me with this??
please let me know if i need to move this to another area.
thanks for any help.
jasonroman is offline   Reply With Quote
Old 03-05-2011, 06:38 PM   #2
1LowToy
Re: back to old timing issue.
Set the timing where the factory says, no more that 3 degrees advances from there. If you have the stock carb there are two idle settings. One will be with the idle solinoid with engin running in drive set at 650 rpm. Unplug the wire from the electric solinoid the idle setting on the primary shaft on the carb set at 550 rpm. If you don't have the stock carb 800 is too high of an idle. That should stop you dieseling when you shut it off.
Stop being so hard on the rear end before it goes bang for the last time.
1LowToy is offline   Reply With Quote
Old 03-06-2011, 09:30 AM   #3
jasonroman
jasonroman's Avatar
thanks for the reply....
not sure where the wire you want me to unplug is???
ive been only adjusting the one idle screw on carb. the on on the driver side of carb.
carb is original. q jet carb.
think i have it at about 24 or 28 right now with no pre ignition after shut off..
im not hard on the truck or the rear. i just want the truck to respond when i gas it.
not sure why 350 wont go like my old one went.
Old 03-06-2011, 10:56 AM   #4
jasonroman
jasonroman's Avatar
forgot to mention, when i took off distributor cap to get access to oil pressure sending unit.....i noticed what looked to oil under distributor cap????
problem headed my way?
Old 03-06-2011, 04:08 PM   #5
csb#356
24 degrees advanced is way too much at idle. Unplug your vacuum advance and set it to 10 or 12 and go from there. As far as the oil in the distributor cap, no its not supposed to be there and I have no idea how it would even get there, but there isn't supposed to be any moisture or anything in the cap.
csb#356 is offline   Reply With Quote
Old 03-06-2011, 04:48 PM   #6
jasonroman
jasonroman's Avatar
i forgot about the vacuum.
did timing without taking off the hose off carb.
think thats what im supposed to do. but didnt.
hopefully tomorrow when its done raining. ill remember what to take off to do the timing
hopefully ill get better results.
thanks for reply
any and all help is much appreciated.
Old 03-12-2011, 01:10 PM   #7
jasonroman
jasonroman's Avatar
guess your right. ill leave it as is...
just didnt know if the diz being turned so far might end up giving me another problem with something else.
but ill see what happens.
Old 03-12-2011, 08:00 PM   #8
cableguy0
Nope the position of the distributor doesnt matter it cant hurt anything.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
