Old 03-06-2011, 10:11 AM   #1
rustbucket67
67 sbc motor mount question
I know this is a stupid question, but I'm new(ish) to the old truck thing. After experiencing the insanity of a '67 with a broken motor mount (WOT under sight load) I decided to park it and replace the mount. However, all the ones that I'm seeing are a little bit different. They look like they'll work, but I wanted to verify. So, the one I have doesn't look like it has as much rubber around the bottom side, but they look fundamentally similar. Just trying to avoid extra time in shipping/charges. Thanks!
Here's a link to the LMC/aftermarket type
http://www.manestruckparts.com/store...Category_ID=16
And here's the one that came off it ...
Also, I've heard of replacing them to a more secure/modern type. Does that mean changing out the frame stand too or is there any other solution I'm overlooking?
rustbucket67 is offline   Reply With Quote
Old 03-06-2011, 10:18 AM   #2
Sammy
Re: 67 sbc motor mount question
Your pic isn't showing up. Just an RED X. If you look thru the build threads you may see some other than stock engine mounts even poly mounts. But stock new mounts should last another 50 years unless your abusive.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
engine, mount
