Old 03-06-2011, 05:50 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
Upper Ball joint removal
Alright, I'm putting new ball joints and springs in the front of my truck. I've got everything torn down (on one side) except for the upper ball joint. I ground out the top of the rivets, but I'm not sure how to get it out. I can't use the press, and no amount of hammering seems to help. I'm thinking about pulling the whole arm out and putting it in a vise. Any help?
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 03-06-2011, 06:00 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Upper Ball joint removal
Pul the arm off and drill them out.
I usually use a grinder to remove the head.
Then just air chisel out the rest of the rivets.
Keith
Convert to disc brakes.
Old 03-06-2011, 06:02 PM   #3
1968CHEVYC10
ok cool thanks
Old 03-06-2011, 06:42 PM   #4
hayhauler71
hayhauler71's Avatar
leave the arm on ,grind off the rivet head, and air hammer them out.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-06-2011, 06:45 PM   #5
cdowns
cdowns's Avatar
use bigger heavier hammer if you dont have the tools the toolsnobs do
Old 03-06-2011, 07:43 PM   #6
hayhauler71
Thank You
Fuzzy
Old 03-06-2011, 07:09 PM   #7
treeboy97
treeboy97's Avatar
I had to grind out the rivets and then move up to a 5 pound sledge. A few good swings and they hit the floor.
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E
2012 Victory Cross Country Touring
I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time.
treeboy97 is offline   Reply With Quote
Old 03-06-2011, 08:56 PM   #8
1968CHEVYC10
Alright thank guys, I ended up grinding down the rivets more, then knocking them out with a punch and a hammer.
Now I'm trying to get the lower BJ in. The press I rented from autozone seems to be too small, none of the sleeves are long enough and the whole clamp is too short. None of the other stores had anything bigger.
Old 03-06-2011, 09:12 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I think I used a BFH on my balljoints, I KNOW I didnt use a press..lol
John
1999 Toyota Tacoma 4x4
Old 03-06-2011, 09:23 PM   #10
Jeffs70
Jeffs70's Avatar
lol same method I used. BFH and they popped right out. and to put the new ones in they should just be bolted on the top and the bottoms I used the same BFH and they popped in after a few hits. also not a bad idea to use a socket to keep from smashing the center where the grease fitting sits.
Jeffs70 is offline   Reply With Quote
Old 03-06-2011, 10:06 PM   #11
Hubscrub
Cruzin
Hubscrub's Avatar
i think i used a bfh on my balljoints, i know i didnt use a press..lol
x2
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-06-2011, 09:21 PM   #12
cdowns
cdowns's Avatar
good reading if it didn't come with instructions
http://www.ehow.com/how_5598087_use-...int-press.html
Old 03-06-2011, 09:23 PM   #13
1968CHEVYC10
you got them in that way? That might work if I pulled the LCA out.
Old 03-07-2011, 04:51 PM   #14
1968CHEVYC10
So when y'all hit the BJ in with a hammer, was the control arm installed?
Old 03-07-2011, 09:33 PM   #15
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
You can install lower ball joints all day long with the lower control arm installed on the truck.
Put the lower bj in the hole, support from the bottom with a solid wooden block. Beat around the lbj with a BFH until the ball joint is seated.
Or go to the auto parts store and get a ball joint press on the "free loaner" program.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-07-2011, 10:00 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
yes i have done it installed and out i try it installed first if ya got enough room to get a good swing under it.
Proverbs 3:5,6
Old 03-07-2011, 09:14 PM   #17
smallblockchev
Take the lower control arm off and use a press.
2007 Chevy 2500HD all stock
1985 Chevy Blazer- sold
1971 Chevy c10- The Mistress
2014 Ford Interceptor SUV
smallblockchev is offline   Reply With Quote
Old 03-08-2011, 10:12 PM   #18
1968CHEVYC10
Hey y'all, spent a little more time messing with the press and got it figured out. It's all put back together now! The new 3/4 ton springs really help around corners and they don't ride to bad, now for some new shocks. Thanks!
Old 03-05-2014, 07:16 PM   #19
eyes
Replacing ball joints in a 1967 C10, I ground the heads of the rivets off so they were flat, center punched it and drilled half way through. I than used a chisel to knock off the tops, punched out the rivets. With the bottom a arms I used a rented puller from parts store. However I used my die grinder to cut away the top part of the ball joint, so I could remove the pin. Once that was done the puller was a breeze, good luck everyone.
eyes is offline   Reply With Quote
Old 01-18-2015, 06:06 PM   #20
gasmn1620
removed mine last night. Just drilled through the top of the rivets enough to be down inside the bj plate. then took a chisel and a bfh and knocked the rest of the caps off. Then 2 smacks with the bfh and the upper bjs went flying across the shop. pretty easy actually. A lot easier than getting the damn bushings out.
gasmn1620 is offline   Reply With Quote
