Dropmember pinion angles?
Hey guys i just got done installing my cab on my square body. I have a porterbuilt dropmember newest version. I am running a vortec 350/4L60E. Now when i set up the drive train in the truck i set the pinion angle at i believe 3 degrees now when i put the cab on it hit the tranny and keeping the cab up about 2" in the front lucky i dropped the tranny x member down so i had room for my exhaust. I was able to take out the spaced i had in and that left me with enough room to drop the cab on. Now i through the angle finder on the motor intake and it was showing about 8 degrees. Is this normal? what are you guys running for pinion angels?
Thanks, Billy ![]() Motor with spacers installed while making my Y pipe ![]()
My build thread. Boy what did i get myself into! Last edited by draggin86; 03-06-2011 at 07:43 PM. |
Re: Dropmember pinion angles?
I asked Nathan about this when trying to determine possible mods to my trans x-member on the chassis for my 64. He recommended 5° @ the trans. Once I started playing around w/that specific target, it was apparent drive-line angles would be needing a 2pc shaft set-up or a CV set-up. I would call him & run your specific combination of parts by him & see what he suggests.
For my set-up, I raised the trans so it's about 2.X° & left the pinion for the truck-arm rear 'as-is' (approx 2.2° down). This put my 1pc d.shaft @ about a .4° declining slope from the trans to the pinion @ ride height. This required floor mods but I think that's better vs. other options. It was definitely the cheaper choice.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-06-2011 at 08:15 PM. |
Thanks SCOTI I talked to him a little before and he said there shouldnt be any mod need to the floor, but at this point its not looking good! I hope he will chime in and give some input!
My build thread. Boy what did i get myself into! |
#4 | |
Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Thanks Nate! PM sent!
Thanks nate! great customer service as always!
Anytime Billy! Glad you're feeling better!
