03-06-2011, 10:24 PM | #1 |
Filling Holes in Firewall - My Solution
As they say, hindsight is 20/20. When I had my cab painted I overlooked having the holes in the firewall sealed up. Had I been thinking, every hole would have been welded and painted. Instead I was stuck with all those open holes in the firewall. today I finally decided to do something about it.
I picked up some trim fasteners from my local autoparts store. These are the same fasteners used to hold door panels. Out of the package they are black, smooth and glossy looking. I used light sand paper to remove the gloss then sprayed them with primer. Once dry, I lightly sanded the primer with 600 grit. I then spray them with a base coat of Atomic Orange from a rattle can. After an hour I went over it with automotive clear also from a rattle can. The results were better than expected. In the photos below they are sitting over the holes but not yet secure. I plan to cut small pieces of leftoever Dynamat to cover the holes from the inside. Then pierce a hole and push them into place. I still need to fill the remaining holes and add grommets where the wires pass thru. When it's done it will look way better than all those holes! After spraying base coat Atomic Orange After applying clear coat Firewall holes before Firewall holes after
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb Last edited by AusTx68; 03-06-2011 at 10:28 PM. |
03-06-2011, 10:30 PM | #2 |
Re: Filling Holes in Firewall - My Solution
03-06-2011, 10:51 PM | #3 |
thats perfect, just the solution i was looking for! just gotta love the info on this board
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
03-06-2011, 11:09 PM | #4 |
Formerly- 1972SuperCheyenne
Looks great. Much better than all the unused holes there! Great job!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
03-07-2011, 12:25 PM | #5 |
Excellent Idea!
Marking for future reference
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
