Old 03-07-2011, 11:36 PM   #1
cbmjm
Rear main seal
So I am going to attempt to replace the rear main seal, one mech. told me im gonne have to drop the tranny, and another said i can access it by dropping the oil pan. Any advice on this? any special reading i can do that will help?
The motor is the original 253 inline 6. I'm new to the forums and any help would very much appreciated.
Mike
cbmjm is offline   Reply With Quote
Old 03-08-2011, 01:32 AM   #2
andyh1956
Re: Rear main seal
greetings. do you mean a 235? if so, it should have a rope seal around the crank under the rear crank bearing. it can be got after by removing the oil pan & the rear main bearing cap. it will probably be rock hard & will come out in chunks. be careful not to scratch the shaft. they make a tool for the job & i have bought several over the years but they never worked for me. when you get the new one in try to stagger the ends a little off with the parting surface of the block & cap so the oil won't have a straight shot out of the engine. hope this helps a little.
andy
andyh1956 is offline   Reply With Quote
Old 03-08-2011, 07:08 PM   #3
steve'62
steve'62's Avatar
Re: Rear main seal
Mine is leaking too, sounds like a pain!
steve'62 is offline   Reply With Quote
Old 03-08-2011, 07:31 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Rear main seal
Langdon’s Stovebolt Engine Co.
http://stoveboltengineco.com/
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
