Pitman arm is loose but cant get it off...
I have the pitman arm unbolted and free from the drag link and the steering box shaft, BUT I cant seem to remove the arm. if I angle the arm up, it hits the shaft and wont free the other end for the drag link. there doesnt look to be enough play. This doesnt seem to be normal, Is there some trick?
Thanks, Tony Last edited by ihatericeburners; 03-10-2011 at 08:52 PM. |
Re: Pitman arm is loose but cant get it off...
If we had a pic of your situation I'm sure we could help you solve this.
![]() Last edited by ihatericeburners; 03-10-2011 at 09:12 PM. |
got her.
Its a Truck Thing......
There is a special tool to remove the arm.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
yes. the arm is unbolted and loose on both ends but i am unable to remove it completely because both ends bind. preventing it from moving up down or side to side.
turn the wheel all the way to the right to make the arm come towards the picture. should be able to drop once rotated
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
and i have to finish tonight and get to work tomarrow.
Or you can loosen the idler arm at the frame and it will drop the drag link so it should be a breeze.
Tighten it back up on the power box then use a long screw driver to pop out the other end, then take it back off the box. I did it about a month ago that way. It was still hell to get back on again.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
