03-10-2011, 10:41 PM | #1 |
Gas hog
I took a little 140 mile round trip in my 72 GMC 4X4 the other day and when I got home my truck was almost empty. I could not believe how much gas I used! As soon as I got home I filled it up again ($60) so I could check the milage. I got up the next morning and my tank was almost empty! Looked under my truck and saw a nice stream of gas flowing out of my fuel pump, the diaphram must have torn. I don't know how I could have missed the smell of at least 15 gallons of gas on the ground, I looked under the truck and could see where the gas had been spraying all over under the truck, I think I am very lucky there wasn't a spark or enough heat to ignite the gas and burn my truck to the ground! Counting nearly two tanks of gas and parts, this was the most expensive fuel pump I ever bought!
Posted via Mobile Device |
03-10-2011, 11:12 PM | #2 |
Re: Gas hog
Check/change your oil too. If the diaphragm tore, it could leak gas into the crankcase. Oil level would be overfilled and diluted.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
03-10-2011, 11:13 PM | #3 |
Re: Gas hog
I had that happen on my '59 chevy....but with the carb and it filled the motor up. I was lucky it didnt explode or anything! The motor sure is clean now though!
1955 GMC Hydramatic 1959 Chevy Spartan 100 1969 Chevy C/10 1969 Chevy C/30 Bruiser 1972 GMC (Wrecked) 1972 GMC pickup..old blue Restored Vent Windows https://67-72chevytrucks.com/vboard/...d.php?t=766598 1955 GMC hydramatic build http://67-72chevytrucks.com/vboard/s...d.php?t=429417 Last edited by blue 72 gmc 4x4; 03-10-2011 at 11:14 PM. |
03-10-2011, 11:18 PM | #4 |
What?
Re: Gas hog
Yep, seen that before.
Except there was no external leakage, and all the fuel was pumped into the engine. Interesting when you go to drain the oil with a pan big enough for a few quarts, only to get a few gallons of unleaded first then 5 quarts of engine oil. BTW, the engines bearings were toasted and the engine had to be torn down in my case. This was a friends old elCamino that he asked me to troubleshoot why it wouldn't start...
Chris 1968 K20 Suburban 1972 K10 LWB PU |
03-11-2011, 12:36 AM | #5 | |
Re: Gas hog
Thanks a lot for pointing that out! Posted via Mobile Device |
03-10-2011, 11:49 PM | #6 |
Hellasick
Re: Gas hog
Man, real lucky finding the leak before more than the gas was lost.
Found a gas leak in a '70 Bug I used to have from the massive loss of gas, 'cept it was in a fuel line IN the engine compartment
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
03-11-2011, 12:40 AM | #7 |
its all about the +6 inches
Re: Gas hog
go out and check the oil now. If it is way over full, then you know you need to change the oil. If it is where it should be, then there is no need.
03-11-2011, 12:54 AM | #8 | |
Re: Gas hog
03-11-2011, 12:45 AM | #9 |
Grandpa in the rustmobile...
Re: Gas hog
I lost a motor this way too..
Check your oil! And DRAIN it quick then change it a time or 2 and hope for the best.. Although it was a good excuse to build a new motor
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-11-2011, 01:29 AM | #10 |
Re: Gas hog
it should be ok
03-11-2011, 01:54 AM | #11 |
Re: Gas hog
03-11-2011, 01:59 AM | #12 |
Re: Gas hog
lol, your welcome
03-11-2011, 10:44 PM | #13 |
Re: Gas hog
Well I drained my oil today, I had changed it less than a month ago so the oil should have been fairly clean, it was clean the last time I drained it, this time the oil was black, I mean black. It was also thinner than it should have been. When I checked it this morning it was a quart high, I assume that extra quart could be gas. I bought five quarts of cheap oil, dumped out the filter and put it back on and ran the engine awhile, drained it, changed the filter and then refilled it with some good oil.
The engine still runs great, smooth, good oil pressure and doesn't heat up at all. I think I escaped without any damage. I will definately remember to check my oil out if I ever have another fuel pump fail! Thanks to all who suggested I check out the oil for gas! You may have saved an engine! Posted via Mobile Device |
