Old 03-10-2011, 10:46 PM   #1
GMC70c20
gauges for a lq4
I put a lq4 in my truck and was wanting to use the factory sensors and leads from the ecm to run the gauges. I want to use aftermarket gauges, what gauges can I use?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 03-11-2011, 12:22 AM   #2
ls1nova71
ls1nova71's Avatar
Re: gauges for a lq4
You really can't use the factory sensors for anything but the factory LQ4 gauges. If you're going to use aftermarket gauges, they should come with their own senders.
ls1nova71 is offline   Reply With Quote
Old 03-11-2011, 03:26 AM   #3
matthew20061
69' Chevy Stepside
matthew20061's Avatar
You can use the LQ4 speed output on the transmission, the coolant temp (on mine at least some can't) and possibility the oil pressure sender but that might not be very accurate...
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 03-11-2011, 06:30 AM   #4
ls1nova71
ls1nova71's Avatar
Yes you can use the VSS in the transmission, but most gauge companies I've dealt with say not to run it offf the wire coming from the PCM, they usually say to tap directly into the wires coming out of the sensor. As for the temperature sender I would just use the one that comes with the gauge so you know it's accurate. I know if you use a three wire sender from a '98 LS1 they will sometimes work, but why bother if the gauge comes with one.. and for the oil pressure, I've never seen a factory one work with aftermarket gauges. Your best bet would be to either tap the bypass block above the oil filter, or you can get an adapter to put the aftermarket sender on the stock location, but generally they are too big to fit there. If it will fit there and you can't find an adapter you can break the plastic part of the original sender off and drill and tap the aluminum base of it and make an adapter out of that.
