03-14-2011, 08:12 PM | #1 |
Need info on the NV4500 for a swap.
I found what I think is a Nv4500 5speed, but its out of a 2wd. The up side to it is I mite be able to get it for free.
So my question is can you convert it to a 4wd? Its in a 95-97 Chevy 3500 pickup. My other question is how hard is it to swap into my 72, its a factory auto truck with a 454, th400 and a np205, so I know I'll need a clutch petal assembly but what else will I need. I'm going to look threw the forums to see what I can find on my own but any help would be greatly appreciated.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. |
03-14-2011, 08:35 PM | #2 |
Re: Need info on the NV4500 for a swap.
You can convert it to 4wd, but finding the tailhousing can be tricky. I had one that I was gonna do it to, but couldn't find one. And when I did, they wanted an arm and a leg for it, couple hundred more could have gotten a 4wd front the start.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
03-14-2011, 08:50 PM | #3 |
Do you have to change the out put shaft too or is it a direct swap?
03-14-2011, 09:37 PM | #4 |
Yep. I had the parts wrote down somewhere that needed to be changed, was only 4 pieces. Output shaft, tailhousing, bearings and a nut maybe?? Been a couple years...
03-14-2011, 09:49 PM | #5 |
I read a couple forums about it on here and they made it seam really complicated to do. What about hooking up the clutch and the pedal, how difficult will that be?
03-14-2011, 10:19 PM | #6 |
That I don't know about, having got that far on mine yet!!!!
03-14-2011, 10:49 PM | #7 |
MrBeast just filled me in on this on my thread, using the hydraulic clutch out of the donor rig and a divorced t-case. sounds a lot cheaper and easier sense I do all the work on this myself due to the lack of fun tokens to have someone else do it.
03-15-2011, 07:57 AM | #8 |
The turbo 400 with the np205 is it the round pattern ?
Did you read this thread http://67-72chevytrucks.com/vboard/s...d.php?t=437451 and this one http://67-72chevytrucks.com/vboard/s...d.php?t=431033
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! Last edited by duallyjams; 03-15-2011 at 08:00 AM. |
03-15-2011, 11:02 PM | #9 | |
