Old 03-16-2011, 03:10 PM   #1
IGOR
IGOR's Avatar
Painting 8.1 or any other LS engine?
So - I bought an 8.1 last month.
I want to clean it up a bit - paint it - but am not planning to rebuild it.
Any advice on how to clean up this motor without damaging sensors?
My neighbor has a sandblasting business, and I'm very tempted to use him - but don't want to leave sensors on block and get them blasted to heck. Any good ideas on sealing holes with sensors removed?
How do you guys prep these things for paint? Is it best to use a small 90 with the pads?
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 03-16-2011, 03:31 PM   #2
Clyde65
Clyde65's Avatar
Re: Painting 8.1 or any other LS engine?
I wouldnt do the sand blasting at all, even on a rebuild. just use some engine degreaser, bag all the sensors on the truck, use rubber bands tight around the base. clean with wire brush where you can and a scotch brite pad where the brush wont fit.
I cleaned mine that way, used brake clean on a scotch brite pad,let it dry and sprayed with engine enamel...orange in my case.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-16-2011, 03:48 PM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
^^^Agree. Wire wheel is your friend here.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 03-16-2011, 04:08 PM   #4
jays68yak
jays68yak's Avatar
I used purple industrial cleaner and a pressure washer on mine. Then painted with duplicolor engine paint.
And heres a hella fuzzy picture.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 03-16-2011, 04:20 PM   #5
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I always just remove the sensors all together. You can buy bags of plugs from Harbor Freight to plug the holes once you pull the sensors out. Soak the engine with Simple Green then hit it with pressurized water and paint’er up! I think an 8.1L would look awesome is good ole Chevrolet orange.
The 8.1L has a dry intake with resuable gaskets so you can pull the intake off completely when you paint it.
Here is a TBI 350 I did a few years ago. Simple Green and power wash then remove sensors, and painted it.
After paint and reassembly. Rattlecan rebuild!
DirtyLarry is offline   Reply With Quote
Old 03-16-2011, 07:35 PM   #6
IGOR
IGOR's Avatar
Larry -
What about the other cast aluminum pieces on this engine? Are they "dry" seals as well?
I would like to pull timing cover, valve covers, oil pan, and intake during this process -
I'm toying with the idea of getting them either powder coated, polished, or chromed.
-Ben
Old 03-16-2011, 10:48 PM   #7
DirtyLarry
DirtyLarry's Avatar
What I mean about the intake being dry is there is no coolant flowing through it. The oil pan and valve covers have reusable gaskets as well. Depending how many miles and heat cycles your engine has been through will determine if they will actually be reusable. You’ll know when you take it apart as the gaskets will either fall apart or stay intact. The timing chain cover has a formed reusable gasket also but has a lot of sealant towards the oil pan side so I would just pull the cam sensor and paint it still on the engine. Actually, I would paint everything right on the engine but I personally am not into shinny stuff like polishing or chroming. If nothing leaks now, why bother pulling that stuff off and potentially creating a leak.
Also, this is a good time to change the crank sensor while the engine is out, especially if it has around 80 to 100K on it, as you will absolutely not be able to change it once it is in the truck. If your engine has aluminum valve covers you already have the latest design crank sensor. If it had black valve covers you would definitely want to change the crank sensor to the later design, which GM superseded the part numbers anyway so you automatically get the later sensor regardless of what year 8.1L you order the crank sensor for. The early design crank sensor has two o-rings (one at the top and one at the bottom) while the later only has one at the top of the sensor.
