Old 03-17-2011, 03:02 AM   #1
digds83
tranny swap
hi guys im new to the website and am wondering if some one could help me out. im a about to put a five speed out of a 95 chevy 4x4 1500 into my 83 chevy and am wandering wat transfer case i need to use to make the swap work
digds83 is offline   Reply With Quote
Old 03-17-2011, 08:39 AM   #2
James McClure
One shot, one kill.
Re: tranny swap
Dig, your going to have a tough time of this because output on 88 and later transfer cases is on the left side of the vehicle and 87 back is on the right side. There must be someone that makes an adapter to fit older cases to newer transmissions. Thats what stopped me from putting in a HD 5 speed into mine. I never did try to find an adapter. Mabey gear vendors??? jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-17-2011, 08:49 AM   #3
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: tranny swap
There's a very slim lot to choose from for a good transfer case that will bolt right up. If you can find a 89-91 NP241 from a Suburban or 1-ton pickup, that would be the very best way to go. You can get an NP208, as long as it's got the right input shaft. Some NP205's will work, but they're ridiculously rare.
Personally, I decided to go with a Jeep Dana 300 on mine. It bolts right up, but I had to get a new input shaft for it. It cost me about 180 bucks and some busted knuckles tearing it apart, but better than the 600-700 I was looking at to get a matching transfer case.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 03-17-2011, 03:18 PM   #4
digds83
Re: tranny swap
so are the np 208 and 205 the transfer cases that came out on the 700r4 trannys
Old 03-17-2011, 03:27 PM   #5
lindstromjd
Re: tranny swap
NP208's are chain driven T-cases. NP205's are gear driven. They both came on a few different types of transmissions.
Your best bet is probably going to be find a good transfer case that you like, and get an adapter for it. I got lucky with my Dana 300.
http://www.high-impact.net/transmiss...case_np208.htm
That's where I got all my info from. Play around a little on the site and figure out exactly what you need to do and go from there. Just remember it's much easier to adapt the transfer case than it is to change the output shaft on the NV4500.
-357 / 700r4
-350 / TH350
Old 03-17-2011, 03:26 PM   #6
digds83
Re: tranny swap
well guys im gonna go try a few transfer case match ups with my tranny i will let u guys know wat i find out
