Brake System Troubles
Ok here goes- I have a 66 with a 350 engine. I have been completely redoing the truck from frame off...... I have new brake lines from front to rear.... Disc on the Front... Drum on the back... a new master/booster combo from Tuff- stuff.... I have completely redone the rear drums all new stuff... as well as the fronts... I used the old calipers though because they are in really great condition. Here is the problem... after completely bleeding the system, I have a great hard brake pedal until I crank the engine, then the pedal goes right to the floor........ I have re-blead the system and checked all the line connections...
???? anyone have any answers as to how to fix this ???? Thanks, Keith |
Just here to tinker
![]() Join Date: Jun 2008
Re: Brake System Troubles
Are you getting a good straight stream out of each bleed valve? Did you top off the reservoir?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
Yes, I'm getting a pretty good stream out of each bleeder valve. and I did make sure and top off the reservoir.
Resistance is Futile
Are the rear drum shoes adjusted out for a friction fit when installing the drum??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I checked them and the are rubbing the pads when I turn them. I have also spoken with another guy, and he said to check the vacuum when the motor is at 2500 RPM. I did and still no luck. .... I bleed the line into a bottle of fluid bubbles come out I shut it down when the bubbles disappear. I do this on all 4 wheels. I have a really hard pedal, I start it up and the pedal goes right to the floor. I start over bleeding and bubbles come out.....I've done this process about 6-8 times.... UUUGGGGHHHH!!!!!!!
Can you say frustration!!! Keith |
![]() Join Date: Aug 2004
bad booster?
Do you have good vacumn on your hose to the booster?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
