View Poll Results: Poll Question¿ | |||
Clear? |
0 | 0% |
Can viewer help? |
2 | 100.00% |
Voters: 2. You may not vote on this poll |
1971 Chevy Cheyenne 10 Fleetside Long Bed, 2WD, 350/4bbl, AT.
Seeking instructions to remove & test: (a) Dash gas gauge. (b) Gas tank sending unit. Diagrams would be plus. Please do not use this thread for other topics or comment on text & color choices. Thanks. ![]() |
Re: Gas Gauge & Sending Unit Remove/Test
Here is a link to a page that has a drawing and instructions for troubleshooting gas gauge problems.
http://www.6066gmcguy.org/Electrical-02.htm Worked well for me on my 69 GMC a few years back.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Disconnect the sending unit wire. Ground it out and the gauge should move (to empty I believe) with the key on.
The resistance on the sending unit should read 0-90 ohms from the post to ground. Just replaced mine and works fine now. Classic Chevy had the best price $30, that I found. LMC was $50.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress Last edited by dmack91; 03-18-2011 at 02:34 PM. Reason: corrected - thanks VetteVet |
#4 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I believe you meant to say that the SENDING unit should read between 0 and 90 ohms depending on the float position.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#5 | |
Well the good tech has been covered but I have a question regarding the pole, what does it pertain to?
Edit>>> I mean poll.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
![]() Join Date: Jan 2001
#7 | |
Pole or Poll? To strip or not to strip, is that the question?
Well this non-existant pole has helped me. I found it by by accident searching for gas gauge fixes. Poll, pole, or Pole, I don't care. I now know my sender is the problem, so thanks to all.
Back to your regularly scheduled pole, with no question.
1962 Chevy K10 factory 4x4 stepside longbed http://67-72chevytrucks.com/vboard/s...d.php?t=494632 1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded 1968 Chevy 1/2 ton panel wagon, V8 and powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=483345 1978 Ford F250, beater stepside 2008 Jeep Wrangler 4 Door 2010 Chevy 4x4 plain jane work truck |
Tags |
gas gauge, sending unit |
